Problem to run simpleFoam using qsub?
Old   December 21, 2015, 06:54
Default Problem to run simpleFoam using qsub?
M. Montero
be_inspired is on a distinguished road
I am having problems to run a simulation using qsub.
It works ok not using qsub:
Using mpirun --hostfile machines -np 504 simpleFoam -parallel > log &
But using:
qsub -cwd lanza.sh
With lanza.sh:
#$ -j y
#$ -S /bin/bash
#$ -pe ompi 504
#$ -q lenovo.q
#$ -m be
#$ -M mail@mail.com
. /opt/OpenFOAM/OpenFOAM-2.1.1/etc/bashrc
echo "Start"
mpirun -np 504 simpleFoam -parallel
echo "End Parallel Run"
I obtain these files and the run does not progress:
lanza.sh.po38
-catch_rsh /opt/sge/default/spool/nodo01/active_jobs/38.1/pe_hostfile
nodo01
nodo01
nodo01
nodo01
nodo01
nodo01
nodo01
nodo01
nodo01
lanza.sh.o38
Start
Host key verification failed.
A daemon (pid 8509) died unexpectedly with status 255 while attempting
to launch so we are aborting.
There may be more information reported by the environment (see above).
This may be because the daemon was unable to find all the needed shared
libraries on the remote node. You may set your LD_LIBRARY_PATH to have the
location of the shared libraries on the remote nodes and this will
automatically be forwarded to the remote nodes.
mpirun noticed that the job aborted, but has no info as to the process
that caused that situation.
End Parallel Run
Any idea ab
be_inspired is offline   Reply With Quote
Old   December 22, 2015, 12:53
Joachim Herb
jherb is on a distinguished road
can you login into all nodes using ssh without giving a password?
jherb is offline   Reply With Quote
topoSet simpleFoam parallelized run error HakikiCanakkaleli OpenFOAM Pre-Processing 5 October 5, 2018 10:52
Problem in simpleFoam airFoil2D forceCoeffs junkie71189 OpenFOAM Running, Solving & CFD 31 March 11, 2017 21:56
Help Troubleshooting simpleFoam problem on Harpoon made mesh lhcamilo OpenFOAM Bugs 1 February 18, 2009 07:11
transient problem run in steady state luigi FLUENT 4 March 13, 2008 06:54
Problem on Parallel Run Setup Hamidur Rahman CFX 0 September 23, 2007 17:11
