omega wilcox definition
Old   May 9, 2016, 11:37
Default omega wilcox definition
giammy92 is on a distinguished road
I'm using k-omega SST model in Low-Re mode so without wall functions.
I set omega with fixedValue calculated with wilcox's formula:
omega = 6*nu/(0.075*y^2)
in which y should be the first cell center nearest to wall. How i can calcaulate this? Is there an utility for this?
giammy92 is offline   Reply With Quote
Old   May 11, 2016, 17:13
Clara
risku9 is on a distinguished road
Dear giammy92,
What do you need to calculate? y or omega? or you want to calculate omega within the code directly?
Cheers!
risku9 is offline   Reply With Quote
Old   May 11, 2016, 18:37
Hi risku9, I want calculate omega with wilcox formula at wall because I think that is more accurated compared to omegaWallFunction. I need to know y in formula that should be the first cell center right? Is there an utility to calculate it?
Old   May 11, 2016, 18:48
Clara
Hey!
If what you want to get is y, I think you can find it in the wall function definition of omegaWallfunction:
src/turbulenceModels/incompressible/RAS/derivedFvPatchFields/wallFunctions/omegaWallFunctions/omegaWallFunctions
You can find this piece of code:
const scalarField& y = turbulence.y()[patchI];
Which I believe refers to the nearWall distance, as if you look into the C++ documentation of OpenFOAM:
http://openfoam.github.io/Documentat...ml/a01744.html
Looking for turbulenceModel::y() and clicking on it you will reach:
http://openfoam.github.io/Documentat...ce.html#l00157
where it explains:
//- Return the near wall distances
158 const nearWallDist& y() const
159 {
160 return y_;
161 }
So I think if you use that turbulence.y() as in the omegaWallFunction now, you should be able to get to do what you would like!
I hope this helps! =)
Old   May 12, 2016, 07:11
Sorry i haven't understood well what i have to do to obtain near wall distance.
Old   May 12, 2016, 12:27
Clara
Hey,
So I think you would just need to create a new wall function, in which you set that omega to the value you want. I was checking the original OmegaWallFunction in the code in the folder of installation of openfoam:
OpenFOAM/src/turbulenceModels/incompressible/RAS/derivedFvPatchFields/wallFunctions/omegaWallFunctions/
And it is almost already what you are looking for as beta1_ = 0.075, you would just need to comment the omegaLog component.
If look in line 234 from omegaWallFunction.C file:
// Set omega and G
forAll(nutw, faceI)
label cellI = patch.faceCells()[faceI];
scalar w = cornerWeights[faceI];
scalar omegaVis = 6.0*nuw[faceI]/(beta1_*sqr(y[faceI]));
scalar omegaLog = sqrt(k[cellI])/(Cmu25*kappa_*y[faceI]);
omega[cellI] += w*sqrt(sqr(omegaVis) + sqr(omegaLog));
G[cellI] +=
w
*(nutw[faceI] + nuw[faceI])
*magGradUw[faceI]
*Cmu25*sqrt(k[cellI])
/(kappa_*y[faceI]);
Behaviour of the kOmegaSST in a steady-state case Max1234 OpenFOAM Running, Solving & CFD 18 October 31, 2018 08:03
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
how to calculate the omega at inlet boundary in k omega sst Scabbard OpenFOAM Running, Solving & CFD 2 September 30, 2014 13:06
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
Definition of omega jpo FLUENT 4 April 7, 2009 15:06
