solving problem after converting fluent mesh to faom
Old   November 14, 2016, 08:37
Default solving problem after converting fluent mesh to faom
sangram
sangram is on a distinguished road
Hello everyone,
I have imported mesh (.msh) file from fluent to OpenFoam. I am using chtMultiRegioSimpleFoam solver. I have specified corresponding boundary conditions in the "0" folder. After running " ./Allrun " I am getting following error message in log file-
Please let me know if anyone has idea about this error message
Create time
--> FOAM FATAL IO ERROR:
cannot open file
file: /home/anv25/OpenFOAM/anv25-2.4.0/run/tutorials/heatTransfer/chtMultiRegionSimpleFoam/heatsinkkk/constant/regionProperties at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 87.
FOAM exiting
sangram is offline   Reply With Quote
Old   November 14, 2016, 17:15
khedar
khedar is on a distinguished road
You need to define a file called 'regionProperties' in case 'constant' directory which specifies the regions for fluid and solid. Please check one of the tutorial cases for chtMultiRegionSimpleFoam solver.
When OpenFoam cannot find some file, I would google about the function of the file and provide OpenFoam with the file so that it can run without complaining.
khedar is offline   Reply With Quote
How I can introduce my power heat (W) in chtMultiRegionFoam? aminem OpenFOAM Pre-Processing 32 August 29, 2019 02:23
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 05:07
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
