solidDisplacementFoam linear? nonlinear?
Old   November 6, 2016, 08:24
Default solidDisplacementFoam linear? nonlinear?
Xiaoxue Shen
xiaoxue is on a distinguished road
Hi everyone,
I applied the solidDisplacementFoam to analyse a simple case, a plate (1m*1m*3mm) with four edges fixed ,and put a constant 10 Pa force on one of the remainder face, the other with 0 Pa(using tractionDisplacement BC). The geometry is in like picture "Selection_016.png". and I set the d2dt2Schemes under the fvSchemes dictionary Euler. The displacement of the point at center of the plate is like the "Selection_017.png". It seems that there is nonlinear factors in it.
But the solidDisplacementFoam solver is a linear solver, I was really confused about this. Anybody can help me with this... I would appreciate it very much.
Wishes,
Xiaoxue
The D dictionary is
FoamFile
version 2.0;
format ascii;
class volVectorField;
object D;
dimensions [0 1 0 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
consoleFixed
type fixedValue;
value uniform (0 0 0);
consoleSolid1
type tractionDisplacement;
traction uniform (0 0 0);
pressure uniform 0;
consoleSolid2
pressure uniform 10;
xiaoxue is offline   Reply With Quote
Old   November 30, 2016, 13:02
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi Xiaoxue Shen,
You are correct, solidDisplacementFoam assumes a linear analysis:
  • Linear geometry: small strains and rotations
  • Linear material: stress is linearly proportional to strain
  • Linear loading conditions: the standard boundary conditions are linear functions of displacement
Why do you think you are getting nonlinear results?
From your results for the displacement vs. time at the centre of the plate, the decay in the displacement amplitude suggests numerical dissipation: this is consistent with the use of a 1st order time integration scheme (backward Euler).
If you would like to reduce this numerical dissipation, you can try the following:
  • a smaller time-step
  • a higher order time differencing scheme e.g. "backward" is second order; though finite element methods typically use Newmark-beta schemes.
Philip
bigphil is offline   Reply With Quote
Old   December 4, 2016, 20:37
Xiaoxue Shen
Hi Philip,
Sorry to say thanks to you so late. Yes, as you say, after changing a smaller time-step,the dissipation disappeared. And I have to learn more about theories and methods, thanks for your work of solid mechanics and your helpful papers.
Best wishes,
Xiaoxue Shen
soliddisplacementfoam
2nd Order Convergence Problem for 3D Airfoil turkmengokce OpenFOAM Running, Solving & CFD 1 September 10, 2015 07:20
A turbulent test case for rhoCentralFoam immortality OpenFOAM Running, Solving & CFD 13 April 20, 2014 06:32
suitable boundary condition for scavenging process? immortality OpenFOAM Running, Solving & CFD 3 January 25, 2013 19:10
how to modify fvScheme to converge? immortality OpenFOAM Running, Solving & CFD 15 January 16, 2013 13:06
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 01:23
