Coherent structure for LES simulation of flow past plate with Re=50000
Like Tree1Likes
  • 1 Post By Bazinga
Old   December 15, 2016, 15:53
Default Coherent structure for LES simulation of flow past plate with Re=50000
Bashar
Bashar is on a distinguished road
I am working on a simulation of flow past plate using LES simulation. I am looking for away to get the coherent and incoherent structure of the flow behind the plate. I am using the same plate shape in the paper " Incoherent turbulence structure in the near wake of
a normal plate" by By M. KIYA and MATSUMURA. So, any one know how to get the plots in figure 4 and 5 in the attached paper using OpenFoam results ( velocity filed, vorticity)?
Regards,
Bashar
File Type: png Screenshot from 2016-12-15 15-52-16.png (178.7 KB, 50 views)
Bashar is offline   Reply With Quote
Old   December 22, 2016, 07:50
Bazinga is on a distinguished road
You can use Paraview for that.
Paraview can show contours on a plane and has a feature where you can add your own formulas. Just use the cavity tutorial to get started. After that you should be able to apply the software to your case.
Bashar likes this.
Bazinga is offline   Reply With Quote
Some questions about flow boiling simulation in Fluent beastieboys6 FLUENT 8 November 20, 2017 23:47
[blockMesh] Flow domain by BLOCKMESH for plasma induced flow simulation mukut OpenFOAM Meshing & Mesh Conversion 0 June 2, 2014 06:19
Unsteady simulation of flow past wheel Tom FLUENT 8 January 18, 2006 10:54
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 05:18
Simulation of the Flow past a circular cylinder using STAR-CD M. S. GUEROUACHE Main CFD Forum 0 October 1, 1998 10:51
