To tmp or not not?
Like Tree3Likes
  • 3 Post By tiam
Old   March 25, 2017, 21:51
Default To tmp or not not?
Adhiraj
adhiraj is on a distinguished road
Hello all:
I am trying to create a library for my work, and I have a question about the use of tmp in OpenFOAM. I have a little bit of understanding of how it works, but I don't know enough about the implementation to know anything about efficiency (running faster) for my case.
So here is the question:
at every time step I need to obtain a volScalarField phi, and use its value. Something like this
phi = sqrt(a) + sqr(b);
where a and b are volScalarFields.
In this case one option is to define phi as a private member of the class and just do this:
phi *= 0;
The other option is to do this
    tmp<volScalarField> tphi
        new volScalarField
            IOobject
                "phiTemp",
                kappa_.mesh().time().timeName(),
                kappa_.mesh(),
                IOobject::NO_READ,
                IOobject::NO_WRITE,
                false
            kappa_.mesh(),
            dimensionedScalar("zero", dimless, 0.0)
    volScalarField& phi = tphi();
Sine this computation is done several times every time step, which option is better for efficiency purposes, and why?
Any help is appreciated, thanks.
adhiraj is offline   Reply With Quote
Old   March 27, 2017, 08:39
Timofey Mukha
tiam is on a distinguished road
The main idea with tmp is to be able to return a reference to an object created locally inside a function.
Imagine you have a function f() which you use to compute a volScalarField, the size of which scales with your mesh size.
If you use a regular return statement, this will lead to the giant volScalarField being copied. Instead one would like to return a reference to the created field.
But one cannot do that because returning a reference to a local variable is not permitted (which makes sense, since it goes out of scope as soon as you exit the function).
The tmp class allows to by-pass this.
In your case you are directly updating a member of a class, so I don't think tmp will bring any benefit.
floquation, ugurtan666 and lpz456 like this.
tiam is offline   Reply With Quote
[IHFOAM] The IHFOAM Thread Phicau OpenFOAM Community Contributions 392 September 8, 2023 18:10
call a tmp formal value without a parentheses? sharonyue OpenFOAM Programming & Development 4 May 23, 2020 17:48
error adding void fraction into the solver & Error when chemistry is on cmigueis OpenFOAM Programming & Development 23 August 14, 2016 14:53
LES correct function luiz eduardo OpenFOAM Running, Solving & CFD 6 September 14, 2007 04:10
