Calculation of flow rate in Openfoam
Old   May 2, 2017, 07:13
Default Calculation of flow rate in Openfoam
Bharadwaj Bhushan
Bharath Bhushan is on a distinguished road
hello guys,
I am using OpenFoam-2.3.1, and I need to calculate the mass flow rate at inlet and outlet. Please can anybody explain how to do that and to insert the code in control dict.
Thank you
Bharadwaj
Bharath Bhushan is offline   Reply With Quote
Old   May 2, 2017, 08:02
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
You may use the patchAverage or patchIntegrate post processing tools for that.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   May 4, 2017, 05:25
Bharadwaj Bhushan
thank you Uwe Pilz,
I have a doubt that the phi is volume flow rate right what we get in the time directories ?.
Old   May 4, 2017, 08:10
piu58's Avatar
Uwe Pilz
I don't have much experience with compressible media. But you should get the velocity components and the mass density, from which you may calculate the mass flow rate.
Uwe Pilz
Old   May 5, 2017, 01:52
Yogesh Bapat
ybapat is on a distinguished road
Originally Posted by Bharath Bhushan View Post
thank you Uwe Pilz,
It depends on which solver you are using. Check for dimensions of phi in the file.
Regards,
-Yogesh
ybapat is offline   Reply With Quote
[OpenFOAM] Calculation of water mass flow rate through custom plane madfan123 ParaView 0 April 21, 2017 08:19
Volume flow rate boundary condition in OpenFOAM mayank.dce2k7 OpenFOAM Running, Solving & CFD 13 August 11, 2014 20:16
How to calculate phase flow rate? sangramroy FLUENT 0 January 11, 2012 13:02
Discrete Phase & Mass Flow Rate MagnusZeus FLUENT 0 December 2, 2011 17:57
mass flow rate calculation Ahmed CFX 7 June 20, 2008 05:55
