How to generate the streamline from inlet to outlet of a pump
Old   July 4, 2017, 09:22
Question How to generate the streamline from inlet to outlet of a pump
王莹
Alisa_W is on a distinguished road
Hello everyone,
My name is Alisa, a new learner of openfoam. Recently, I am studying simulating a pump.Here are some post-processing pictures of the simulation.
It seems that the pressure contour is reasonable but I am not sure whether the result is right because I don't know how to get the streamline of the internal fluid, as a result of which I can't judge the motion(direction and distribution) of the fluid.
I hope that I have express clearly what I what to say. Any advice or problems, please contact me.I will appreciate any relative ideas! Thank you all!
Alisa_W is offline   Reply With Quote
Old   July 5, 2017, 13:55
Chris L
vbchris is on a distinguished road
Using Paraview.
Add filter stream tracer.
Filters > alphabetical > stream tracer.
Select U (velocity field) as the vector.
click apply.
Move the white ball around and adjust the number of streamlines until it looks nice.
vbchris is offline   Reply With Quote
Old   July 5, 2017, 21:30
王莹
Originally Posted by vbchris View Post
Using Paraview.
click apply.
Thank you~I have tried this method but the streamline seems not so good Is there any skill or key point when moving the ball?Thank you very much!
Old   July 5, 2017, 21:43
Sana Ullah
Mehar is on a distinguished road
Hi, It would be helpful to post the image of what you got.
Anyway, there are a couple of controls that you can use to make streamlines better looking,
1. You have the option to choose between point and line source.
2. You can change the radius of your point, and no. of points.
3. You can increase or decrease length of your streamlines.
4. you can use costume streamlines filter if you want to seed streamlines from a patch or any other surface.
5. You can add tube filter to your streamlines to get nice 3D streamlines.
Hope this can help!
Thank you
Mehar
Mehar, Phd Scholar
KAIST, Korea
Mehar is offline   Reply With Quote
direction of velocity, post-processing, pump, streamline
Inlet temperature = outlet temperature + offset? GerHan OpenFOAM Pre-Processing 5 November 14, 2016 06:36
simpleFoam: Non-uniform mesh near inlet & outlet causes incorrect velocity profile? Zaphod'sSecondHead OpenFOAM Running, Solving & CFD 0 January 28, 2015 05:17
boundary condition for coupled inlet and outlet xxxx OpenFOAM Pre-Processing 2 August 13, 2013 15:51
steam flow in a pipe driven by a pressure gradient between inlet and outlet SalvoCalvo COMSOL 0 March 11, 2010 06:52
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
