July 14, 2017, 06:00 |
No flames from PaSR combustion model
Rep Power: 14 |
Hi All,
I tried to use PaSR to calculate a simple jet flame, firstly used infinitelyFastChemistry model to obtain an fully burning jet flame field, which seem reasonable. Then I changed the combustion model to PaSR, and if course changed other PaSR related parameter. When the simulation goes, the flame is convected downstream and finally it become just cold. What is the problem for the simulation? Anybody also has this experince? I put my combustionProperties, chemistryProperties and reactions below: Code:
combustionModel PaSR<rhoChemistryCombustion>; active true; infinitelyFastChemistryCoeffs { semiImplicit no; C 10; } laminarCoeffs { } noCombustionCoeffs { } PaSRCoeffs { Cmix 1.0; turbulentReaction yes; // useReactionRate true; } Code:
chemistryType { chemistrySolver ode; //EulerImplicit; chemistryThermo rho; } chemistry on; initialChemicalTimeStep 1e-07; EulerImplicitCoeffs { cTauChem 1; equilibriumRateLimiter off; } odeCoeffs { solver Rosenbrock34; absTol 1e-12; relTol 0.01; } Code:
species ( CH4 CO CO2 H2 H2O O2 N2 ); reactions { //- for infinite fast reaction model // methaneReaction // { // type irreversibleinfiniteReaction; // reaction "CH4 + 2O2 + 7.5N2 = CO2 + 2H2O + 7.5N2"; // } //- for PaSR combustion model methaneReaction { type irreversibleArrheniusReaction; reaction "CH4 + 2O2^1.0 = CO2 + 2H2O^1.0"; A 7e+06; beta 0; Ta 10063.8; } hydrogenReaction { type irreversibleArrheniusReaction; reaction "H2 + 0.5O2^1.0 = H2O"; A 4.74342e+12; beta 0; Ta 10063.8; } } |
July 14, 2017, 07:02 |
#2 | |
Rep Power: 14 |
Problem solved. The activation energy is too small, so that the reaction is so weak.
September 27, 2017, 02:50 |
PaSR
Zhiheng Wang
Rep Power: 10 |
Use c= 0 to minimize the turbulent and laminar reaction time scale it must be low reynolds no case try c = in combustion PaSR directory.
FireFoam - Which Combustion Model? | Duy Le | OpenFOAM Running, Solving & CFD | 3 | May 10, 2021 04:43 |
Combustion model vs. chemistry model (thermo type) | wenxu | OpenFOAM | 2 | July 19, 2015 21:15 |
Diff in Combustion Modelling By Species Transport Model & Non-Premixed Combustion | bhanuday.sharma | FLUENT | 0 | June 23, 2015 02:50 |
Partially premixed combustion - model: less/ no temperature rise | sanjeetlimbu | Fluent Multiphase | 5 | April 21, 2015 20:13 |
combustion model | Hennie van der Westhuizen | Siemens | 7 | February 27, 2002 02:10 |
