Error in IcoFoam solver
Like Tree2Likes
  • 1 Post By Quadrolabs
  • 1 Post By Tobi
Old   September 19, 2017, 12:44
Default Error in IcoFoam solver
Sooraj Kamath
Turbuent_FOAMer is on a distinguished road
Hey guys,
I'm new to OpenFOAM. I've gone through the materials but I'm not able to solve this particular error that I encountered while running a case in IcoFoam
--> FOAM FATAL ERROR:
[U[0 1 -2 0 0 0 0] ] == [-grad(p)[1 -2 -2 0 0 0 0] ]
From function void Foam::checkMethod(const Foam::fvMatrix<Type>&, const Foam:imensionedField<Type, Foam::volMesh>&, const char*) [with Type = Foam::Vector<double>]
in file /home/ubuntu/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude/fvMatrix.C at line 1292.
Please let me know where I am going wrong and how I can correct it. TIA
EDIT: Solved.
Turbuent_FOAMer is offline   Reply With Quote
Old   September 29, 2017, 18:53
clapointe is on a distinguished road
Looks like a units issue -- check to make sure that the dimensions are set correctly in the U and p files.
Caelan
clapointe is offline   Reply With Quote
Old   October 2, 2017, 03:01
Quadros
Quadrolabs is on a distinguished road
Can you upload your case file. Check the unit for pressure field file. icoFoam is an incompressible solver. incompressible solver uses pressure as p/rho. so the unit of pressure should be used as [ 0 2 -2 0 0 0 0 ]. For a case of compressible solver you should use [ 1 -1 -2 0 0 0 0].
kindly update how you solve the problem.
Thank you
Tobi likes this.
Quadrolabs is offline   Reply With Quote
Old   October 2, 2017, 07:52
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
@sooray. You edited your post and mentioned nothing about the problem. Please tell other people what the problem was to help others with the same problem . However, I guess the mentioned problem of Quadrolabs is the solution (pressure had wrong units).
Quadrolabs likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
icofoam, openfoam, thermal analysis
Population Balance Modeling (PBM) - Ansys Fluent chittipo FLUENT 164 November 18, 2023 11:54
Why icoFoam solver results are not true for cavity (10000>Re>5000) ? maysmech OpenFOAM 9 February 4, 2020 09:42
Finally starting to explore OpenFOAM, questions on icoFoam solver... JasonG OpenFOAM Running, Solving & CFD 20 July 11, 2012 20:08
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
