LPT - Basset Force
Old   April 3, 2018, 19:33
Default LPT - Basset Force
Joaquín Neira
cojua8 is on a distinguished road
I'm working with basicKinematicCollidingCloud and I'm trying to implement a new particle force: the Basset force (along with drag, lift and other forces).
For this purpose I will use this model https://arxiv.org/pdf/1008.0833 (or another one which needs practically the same input parameters. [Computation of the particle Basset force with a fractional-derivative approach])
So, I'm having the following difficulties:
  1. I need to store all the past relative accelerations of the particle for every particle: \frac{dU_r}{dt}=\frac{d(U_p-U_c)}{dt}=\frac{dU_p}{dt}-\frac{dU_c}{dt}.
  2. The tracking algorithm of OpenFOAM modifies the \delta t in every iteration, so the models above becomes invalid or at least not accurate, since they used a fixed \delta t. Is there any way to fix the \delta t of the particle? or a way to modify the models (this requires more numerics knowledge obviously)
cojua8 is offline   Reply With Quote
basset force, lpt
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 11:12
Basset History Force on STAR-CCM+ Roderick STAR-CCM+ 0 October 15, 2017 20:20
Force can not converge colopolo CFX 13 October 4, 2011 22:03
DEFINE_CG_MOTION and pressure force Teo Fumagalli FLUENT 0 April 11, 2008 10:25
BASSET HISTORY FORCE rana FLUENT 0 February 15, 2008 04:18
