Extract U speed between 50m to 300m distance from a complex surface
Old   July 3, 2018, 04:21
Default Extract U speed between 50m to 300m distance from a complex surface
GuillaumeD is on a distinguished road
Hey everyone,
I am looking to extract wind speed at certain heights according to the wall surface distance.
I currently have a simulation of wind flow over complex terrain (mountains and hills basically), and I want to extract U data between 50m to 300m from the ground. The idea is to use these data later with python or MatLab.
If possible I would like to keep the coordinates of extracted data. For U I would like to have both scalar and vector data.
I was thinking to use a function in controlDict to do it, but I am blocked with the complex shape of the surface. I also had a look at cellDist or patchWave functions.
If you have any idea on how to proceed, I am all yours.
GuillaumeD is offline   Reply With Quote
Old   July 12, 2018, 11:11
Josh
joshm is on a distinguished road
Use the sample utility with nearWalls_interpolated.
joshm is offline   Reply With Quote
complex geometry, extract data, extract volume, terrain, wind engineering
[snappyHexMesh] adding layers on complex terrain surface in SHM potac OpenFOAM Meshing & Mesh Conversion 1 November 9, 2020 06:40
Problem with surface feature extract sandyy235 OpenFOAM 2 November 11, 2016 04:37
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
Bottom and free surface level for complex bottom structure noid Fluent Multiphase 0 July 2, 2014 13:18
[snappyHexMesh] Add additional boundary layers to complex stl surface tobijingles OpenFOAM Meshing & Mesh Conversion 1 October 26, 2011 10:45
