how to set the BCs on a very low pressure reactor |
July 11, 2018, 06:54 |
Hey, everyone, I'm new to the OpenFOAM and I met some difficult problems.
I'm working on a very low pressure reactor by using the reactingFoam. Since the reactor works on a 190Pa pressure and 1700K and it has a very very thin injector, I calculated that the inlet velocity becomes about 1400m/s After I tried this value(disables all reactions), it diverged soon So I think that may be you can give me some advise on this case Now I set the pressure BCs as outlet { type fixedValue; value uniform 190; } inlet01 { type fixedValue; value uniform 190; } and I set velocity BCs as outlet { type inletOutlet; value $internalField; inletValue uniform ( 0 0 0 ); } inlet01 { type fixedValue; value uniform (0 1339 0); } Besides, can reactingFoam handle such a low pressure case? Or should I choose other solvers? Thank you! Hope for the helps |
How to set BCs programmatically | incompressible | OpenFOAM Programming & Development | 6 | November 20, 2017 02:47 |
BCs for extraction system - Velocity or pressure? | THK | FLUENT | 0 | May 31, 2016 08:02 |
Setting up the pressure variation due to tornado in a duct(UDF)+animation | guillaume1990 | FLUENT | 0 | March 3, 2014 11:59 |
Mass flow rate prediction of Purge control valve using set pressure drop | enr_venkat | CFX | 11 | February 27, 2014 11:30 |
How to set up the inlet boundary condition for a low pressure case? | beastieboys6 | FLUENT | 3 | April 10, 2012 22:46 |
