Question/Problem with Convergence - simpleFoam - Pipe-System
Old   March 1, 2019, 03:19
Default Question/Problem with Convergence - simpleFoam - Pipe-System
Timo is on a distinguished road
Hi there!
My Case
I want to simulate a part of a Pipe-System (simpleFoam) filled with air.
See the attached file for an overview, Diameters are from 250mm to 350mm at the tubes . The velocites are around ~ 24 m/s down to 2 m/s at the rectangular part. (Volumetric Flowrate up to 4200 m^3/h)
https://www.cfd-online.com/Forums/me...-geometrie.jpg
If needed i can post also some Pictures of my Mesh.
Im generating the Mesh with SnappyHexMesh out of a Background-Mesh from gmsh. I tried several different mesh-types. First coarse / then fine /with Layers or without. CheckMesh always told me my mesh is ok.
I specify the velocity at the inlet and the fluid can stream out free at the end of the rectangular part, where i set the pressure to 0.
I'm using the kepsilon turbulence-model, but i also tried out the kOmegaSST.
Before i start simpleFoam, im initializing the Domain with potentialFoam.
My Problem
I have the problem that the initial-residual of p is not dropping below the value 0,05 - 0,005. Also the other variables don't reach lower values.
I'm struggling now if this is enough? I guess These values should fall much more for reaching convergence?
The Results do look ok, Velocites are in the expected range. Also the pressure doesnt look false.
So im uncertain right now, if the boundaries are ok for my case. I dont really trust my results..
I would be very grateful, if someone look over my case or can give me some advices what i can do better!
Best regards!
So here is a small part of my solution.output. Most times the values arent changing even after 1000+ iterations.
Time = 150
smoothSolver:  Solving for Ux, Initial residual = 0.00378163, Final residual = 3.17913e-005, No Iterations 19
smoothSolver:  Solving for Uy, Initial residual = 0.00795081, Final residual = 6.85687e-005, No Iterations 23
smoothSolver:  Solving for Uz, Initial residual = 0.00467368, Final residual = 4.40989e-005, No Iterations 18
GAMG:  Solving for p, Initial residual = 0.0132319, Final residual = 8.3468e-009, No Iterations 23
GAMG:  Solving for p, Initial residual = 0.00198833, Final residual = 8.91338e-009, No Iterations 14
GAMG:  Solving for p, Initial residual = 0.000139475, Final residual = 5.24627e-009, No Iterations 10
GAMG:  Solving for p, Initial residual = 1.69987e-005, Final residual = 5.30083e-009, No Iterations 7
time step continuity errors : sum local = 2.43281e-007, global = 6.73135e-009, cumulative = 1.22496e-008
smoothSolver:  Solving for epsilon, Initial residual = 0.0105538, Final residual = 0.000100227, No Iterations 14
smoothSolver:  Solving for k, Initial residual = 0.0144642, Final residual = 0.000144077, No Iterations 18
ExecutionTime = 2162.26 s  ClockTime = 2162 s
Here are all the other important Files of my Case.
fvSchemes
|  \\    /   O peration     | Version:  5                                     |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
    grad(U)         cellLimited Gauss linear 1;
divSchemes
    div(phi,U)      Gauss linearUpwind grad(U);
    div(phi,k)      Gauss upwind;
        div(phi,epsilon)      Gauss upwind;
    div(phi,omega)  Gauss upwind;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
fvSolution
I already played with the Relaxation-values. The ones provided in Motorbike tutorials also didnt Change something
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
solver GAMG;
tolerance 1e-8;
relTol 0;
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
cacheAgglomeration on;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 120;
mergeLevels 1;
maxIter 500;
    Phi
        $p;
    U
        solver          smoothSolver;
        tolerance       1e-8;
        relTol          0.01;
        nSweeps         1;
    k
        tolerance       1e-8;
        relTol          0.01;
        nSweeps         1;
    omega
        tolerance       1e-8;
        relTol          0.01;
        nSweeps         1;
    epsilon
        tolerance       1e-8;
        relTol          0.01;
        nSweeps         1;
SIMPLE
    nCorrectors 1;
    nNonOrthogonalCorrectors 3;
    consistent               yes;
potentialFlow
    nNonOrthogonalCorrectors 10;
relaxationFactors
    equations
        U   0.9;
        k   0.9;
        epsilon 0.9;
cache
    grad(U);
Boundaries:
U
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    outlet
        type pressureInletOutletVelocity;
        value uniform (0 0 0);
    wall
        type            fixedValue;
        value           $internalField;
inlet
        type                fixedValue;
        value               uniform (-12 0 0);
p
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            zeroGradient;
    outlet
            type            fixedValue;
        value           uniform 0;
    wall
        type            zeroGradient;
k
internalField   uniform 0.02;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 0.02;
    outlet
        type            zeroGradient;
    wall
        type            kqRWallFunction;
epsilon
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 0.038;
boundaryField
   wall
        type            epsilonWallFunction;
    inlet
        type            fixedValue;
    outlet
        type            zeroGradient;
nut
dimensions      [0 2 -1 0 0 0 0];
boundaryField
    inlet
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    wall
        type            nutkWallFunction;
        value           uniform 0;
CheckMesh-File
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            4478326
    internal faces:   4058490
    cells:            1368541
    faces per cell:   6.2379
    boundary patches: 4
    point zones:      0
    face zones:       0
    cell zones:       1
Overall number of cells of each type:
    hexahedra:     1146266
    prisms:        48425
    wedges:        0
    pyramids:      0
    tet wedges:    93
    tetrahedra:    0
    polyhedra:     173757
    Breakdown of polyhedra by number of faces:
        faces   number of cells
            4   26247
            5   14342
            6   20343
            7   2
            8   3
            9   86303
           10   12
           12   18976
           13   3
           15   7379
           18   147
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking basic patch addressing...
                   Patch    Faces   Points
                    wall   350661   378310
                   inlet     4354     4505
                  outlet    51327    51795
Checking geometry...
    Overall domain bounding box (-3.88806 -3.63696 -0.632848) (2 -0.04195 1.917)
    Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
    Mesh has 3 solution (non-empty) directions (1 1 1)
    Boundary openness (-1.95926e-016 -1.8415e-015 1.707e-016) OK.
    Max cell openness = 3.4469e-016 OK.
    Max aspect ratio = 7.21486 OK.
    Minimum face area = 2.51639e-006. Maximum face area = 0.00302785.  Face area magnitudes OK.
    Min volume = 4.5284e-009. Max volume = 0.000163703.  Total volume = 2.06708.  Cell volumes OK.
    Mesh non-orthogonality Max: 62.0921 average: 10.7761
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 1.80749 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
Timo is offline   Reply With Quote
Simplefoam Convergence Problem after Scaling by 0.001 CFDy OpenFOAM Running, Solving & CFD 4 July 23, 2018 03:27
Convergence and steady state using simpleFoam sfigato OpenFOAM Running, Solving & CFD 0 February 8, 2013 04:14
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
