Turbulent Kinetic Energy Budget
Like Tree5Likes
  • 3 Post By skyinventorbt
  • 1 Post By mmmn036
  • 1 Post By skyinventorbt
Old   August 26, 2013, 06:28
Default Turbulent Kinetic Energy Budget
skyinventorbt's Avatar
Dr. B T KANNAN
skyinventorbt is on a distinguished road
This utility creates scalar fields of Advection & Production of Turbulent Kinetic Energy by reading U, R & k files.
Usage Instructions
  1. Extract the zip and paste tkeFoam folder to /opt/OpenFOAM-2.1.1/applications/utilities/
  2. [In Terminal] cd /opt/OpenFOAM-2.1.1/applications/utilities/tkeFoam/ and then wmake
  3. After compilation use "tkeFoam -latestTime" or "tkeFoam" in your case.
Hope it will be useful
KANNAN B T
skyinventorbt is offline   Reply With Quote
Old   April 29, 2014, 20:26
Manjura Maula Md. Nayamatullah
mmmn036 is on a distinguished road
This is only good for RASModel. How to implement this one in LESModel?
Thanks
MMMN
vivek05 likes this.
mmmn036 is offline   Reply With Quote
Old   April 30, 2014, 23:43
Post Reply
Dr. B T KANNAN
Thanks
MMMN
Obviously it cannot be used for LES.
From the data set you generate using LES - will have all the fluctuating and mean quantities - so you could write your own utility using the syntax provided in the Programmers Guide.
KANNAN B T
vivek05 likes this.
Old   March 2, 2017, 09:18
Default Rewrite for newer versions?
dholler is on a distinguished road
Would it be possible to rewrite this utility for OpenFOAM 4? The files that are set to #include in this utility are not in OpenFOAM 4.
dholler is offline   Reply With Quote
Old   March 2, 2018, 04:51
Smile Re-writing the utility
Dr. B T KANNAN
Yes, It can be re-written !
Dr. B T KANNAN, PhD, M.I.E,
PhD in Aerodynamics (CFD|Turbulence|Experiments)
Alumnus of Indian Institute of Technology - Madras.
Old   April 18, 2019, 05:43
Default tkeFoam
Vivek
vivek05 is on a distinguished road
Originally Posted by skyinventorbt View Post
Yes, It can be re-written!
I have tried to compile tkeFoam in OpenFOAM 5.0 but unfortunately, it doesn't.
PHP Code:
Making dependency list for source file turbulentIntensityKineticEnergyInletFvPatchSymmTensorField.C
Making dependency
list for source file tkeFoam.C
could not open file calc
.for source file tkeFoam.C due to No such file or directory
could not open file cyclicAMILduInterface
could not open file cyclicAMIPolyPatch
could not open file RASModel
g
++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3  -DNoRepository -ftemplate-depth-100 -I/home/ssvivek/OpenFOAM/OpenFOAM-5.0/src/postProcessing/postCalc -I/home/ssvivek/OpenFOAM/OpenFOAM-5.0/src/turbulenceModels -I/home/ssvivek/OpenFOAM/OpenFOAM-5.0/src/turbulenceModels/incompressible/RAS/RASModel -I/home/ssvivek/OpenFOAM/OpenFOAM-5.0/src/transportModels -I/home/ssvivek/OpenFOAM/OpenFOAM-5.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/ssvivek/OpenFOAM/OpenFOAM-5.0/src/OpenFOAM/lnInclude -I/home/ssvivek/OpenFOAM/OpenFOAM-5.0/src/OSspecific/POSIX/lnInclude   -fPIC -c tkeFoam.-o Make/linux64Gcc48DPInt32Opt/tkeFoam.o
tkeFoam
.C:35:18fatal errorcalc.HNo such file or directory
#include "calc.H"
compilation terminated.
make: *** [Make/linux64Gcc48DPInt32Opt/tkeFoam.oError 1
My guess is that in OpenFOAM 5 calc.H is not available. It might to be loaded with a different name. Could anyone figure it out
Thanks
vivek05 is offline   Reply With Quote
question about turbulent kinetic energy junker4236 Main CFD Forum 19 April 19, 2017 04:46
LES and total turbulent kinetic energy Boerge FLUENT 1 September 8, 2012 11:41
LES of periodic pipe centerline turbulent kinetic energy smehdi609 OpenFOAM 0 November 30, 2010 23:59
what's the macro of SGS turbulent kinetic energy? lcw FLUENT 1 June 13, 2006 03:08
Turbulent Kinetic Energy Olga FLUENT 2 October 11, 2002 15:05
