Case setup with multiple heat generating bodies
Old   May 1, 2019, 10:10
Default Case setup with multiple heat generating bodies
miragemobile is on a distinguished road
Let's say I have one domain of a rectangular prism. It contains a fluid and several solid volumes displacing the fluid at various locations.
If I desire to specify a unique q''' (volumetric heat generation rate) for each solid volume, will I need a unique cellZone and set of thermophysicalProperties for each solid volume?
Thanks for your time,
miragemobile is offline   Reply With Quote
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 15:13
Compressible rhoPimpleFoam Case Setup Help! JonathanG OpenFOAM Pre-Processing 0 July 12, 2017 10:33
conjugate heat transfer case from two meshes skuznet OpenFOAM Pre-Processing 0 July 1, 2014 17:09
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
