Reacting mixtures viscosity
Like Tree2Likes
  • 1 Post By novyno
  • 1 Post By novyno
Old   June 16, 2011, 20:57
Default Reacting mixtures viscosity
José Rodrigues
jose_rodrig is on a distinguished road
Hi
Does anyone know how OF computes the dynamic viscosity of a reacting mixture for the transport equations?
Wonder why OF doesn't ask for an input file with the transport properties like 'transportProperties' as for perfect gas solvers like pisoFoam, etc
THX
Jose
jose_rodrig is offline   Reply With Quote
Old   June 17, 2011, 02:02
Valerio Novaresio
novyno is on a distinguished road
Hi José,
reactingMixture (is derives from multiComponentMixture) is based on a list of thermophysical data (one for each species) for cp, h, S and viscosity. These data are read from dictionary (i.e. in reactingFoam tutorial, in thermophysicalProperties dict one can find the exact location of the thermo data file). Actually (based on my knowledge...) reactingMixture is templated with sutherland model for viscosity. Finally the general behavior of an OpenFOAM mixture (based on my knowledge...) is to define mu_mixture = sum(y_i * mu_i), where y_ i is the mass fraction.
Regards
Valerio
wayne14 likes this.
...The best way to acquire new knowledge is to share it...
novyno is offline   Reply With Quote
Old   June 17, 2011, 05:20
José Rodrigues
Ciau Valerio
Thank you for ur Hint. Can you further point me to the peace of code in the Doxygen docs where mu_mixtures is computed? I was looking for it and I couldnt find.
In fact, for sutherland viscosity model, one needs to parameters, As and Ts, which are the Sutherland parameters and are different for each specie. Also, I am aware of the file thermo.dat that contains the janaf coefficients to compute cp. Are those sutherland coefficient in this same file?
Thx again
Jose
Old   June 18, 2011, 14:51
Valerio Novaresio
Hi José,
have a look on
thermophysicalModels/reactionThermo/mixtures/multiComponentMixture/multiComponentMixture.C
in particular the cellMixture function. Here thermophysical model of the mixture is obtained like a weighted average of the species thermophysical models. So every properties (mu, cp, etc...) are defined in this way (weighted average).
The Sutherland parameters, As and Ts, are the last two coefficients for each species in thermo.dat file. Have a look also to
http://www.cfd-online.com/Forums/ope...ssiblegas.html
Regards
Valerio
wayne14 likes this.
Old   June 24, 2011, 09:49
Yashar Afarin
yashar.afarin is on a distinguished road
Send a message via Skype™ to yashar.afarin
Hi Valerio
I have a question about using Sutherland for computing viscosity. I study Yeqn Code in reactingFoam solver and I think that it use only the same muEff for all of the species. I mean that for example the value of muEff for O2 is the same with CH4 one's but if it uses sutherland equation and CHEMKIN (that have As and Ts for each species) they must be different. I am really confused and worried about it.
yashar.afarin is offline   Reply With Quote
Old   June 24, 2011, 12:21
Yashar Afarin
Hi valerio
In my "Thermo.dat" file that I get from reactingFoam (and also dieselFoam) tutorial, there are only 19 number for each species. I can't find sutherland coefficents it this file. could you please send me or attach your "Thermo.dat" file?
my email: yafarin@gmail.com
Best regards;
Old   June 24, 2011, 12:42
Yashar Afarin
hi
"muEff" is mixture effective viscosity or it is define for each species, at reactingFoam solver-Yeqn?
Old   June 25, 2011, 04:57
Yashar Afarin
Hi Foamers
I found the reason. The value of "muEff" must be equal for all of species. because "muEff=mu+mut" and sutherland coefficient for all of species are the same(for computing "mu"). On the other hand "mut" relates to flow field propertied so is equal for all of species too.
Old   April 13, 2014, 11:20
Default How viscoisity of the mixture is calculated ?
Mieszko Młody
ziemowitzima is on a distinguished road
Dear Foamers,
How is in OF the viscosity of the mixture calculated ?
Is it just linear superposition ? If yes then it seems to be wrong...
Where is it defined/calculated in the source code ?
best and thanks
ZMM
ziemowitzima is offline   Reply With Quote
Old   May 28, 2019, 06:00
Default ReactingFoam
TAKILT Hocine
kévine is on a distinguished road
Bonjour,
j'essaie de simuler la combustion de l'hydrogène avec l'air dans les écoulements supersoniques, le problème je n'arrive pas à avoir les réactions chimiques.
j'utilise ractingFoam.
quelqu'un a une idée d'où viens ce problème ??
Merci d'avance pour votre aide
I try to simulate the combustion of hydrogen with air in supersonic flows, the problem I can not get the chemical reactions.
I am using ractingFoam.
does anyone have an idea where this problem comes from ??
thank you in advance for your help
kévine is offline   Reply With Quote
Eulerian Modeling: Frictional Viscosity Help meangreen FLUENT 1 January 25, 2018 15:13
Turbulence viscosity limited Madhukar Rapaka FLUENT 0 June 26, 2006 03:17
kinematic viscosity at diff temperatures,pressures Mecobio Main CFD Forum 0 November 7, 2005 12:55
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
viscosity of mixtures Karsten Koetter Main CFD Forum 2 August 12, 1999 07:13
