Modifying pEqn: "cannot scale a matrix containing a faceFluxCorrection"
Old   October 30, 2019, 11:45
Default Modifying pEqn: "cannot scale a matrix containing a faceFluxCorrection"
Raunak Bardia
raunakbardia is on a distinguished road
This post is related to the two-phase flow solver isoAdvector in OpenFoam v1706.
I am working to implement a new method to capture surface tension and hence, I am currently playing around with pEqn.H. Here is the pressure matrix I am trying to create.
fvScalarMatrix p_rghEqn
    isLiquid * fvm::laplacian(rAULf, p_rgh)
    + (1 - isLiquid) * fvm::laplacian(rAUVf, p_rgh)
     - isLiquid * fvc::laplacian(rAULf * DPField, isInterfaceOwnerLiquid)
     - (1 - isLiquid) * fvc::laplacian(rAUVf * DPField, isInterfaceOwnerLiquid)
     + isLiquid * fvc::laplacian(rAULf * DPField, isInterfaceOwnerVapor)
     + (1 - isLiquid) * fvc::laplacian(rAUVf * DPField, isInterfaceOwnerVapor)
     + fvc::div(phiHbyA)
"isLiquid" is a volScalarField
volScalarField isLiquid
    IOobject
        "isLiquid",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::AUTO_WRITE
    mesh,
    dimensionedScalar("zero",dimless,0)
On executing this code, it throws the following error. I have attached a copy of the output log as well.
--> FOAM FATAL ERROR:
    From function void Foam::fvMatrix<Type>::operator*=(const Internal&) [with Type = double; Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Internal = Foam::DimensionedField<double, Foam::volMesh>]
    in file /usr/local/openfoam/v1706/OpenFOAM-v1706/src/finiteVolume/lnInclude/fvMatrix.C at line 1242.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/usr/local/openfoam/v1706/OpenFOAM-v1706/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so"
#1  Foam::error::abort() in "/usr/local/openfoam/v1706/OpenFOAM-v1706/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so"
#2  Foam::Ostream& Foam::operator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) at /usr/local/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude/errorManip.H:85
#3  Foam::fvMatrix<double>::operator*=(Foam::DimensionedField<double, Foam::volMesh> const&) at /usr/local/openfoam/v1706/OpenFOAM-v1706/src/finiteVolume/lnInclude/fvMatrix.C:1242
#4  ? at /usr/local/openfoam/v1706/OpenFOAM-v1706/src/finiteVolume/lnInclude/fvMatrix.C:2247
#5  ? at ~/OpenFOAM/rbardia-v1706/applications/solvers/temperatureFoam/pEqn.H:50
#6  __libc_start_main in "/lib64/libc.so.6"
#7  Foam::UOPstream::write(float) in "/home/rbardia/OpenFOAM/rbardia-v1706/platforms/linux64GccDPInt32Opt/bin/temperatureFoam"
Aborted
The error is pointing to the factor "isLiquid", which I am multiplying with the "fvm::laplacian" operation in the formation of the pEqn matrix. This multiplication apparently is not allowed for matrices that use face flux correction often implemented for non-orthogonal matrices by using the corrected laplacian scheme as shown here. The fvSchemes file I am using is also attached.
laplacianSchemes
    default         Gauss linear corrected;
However, my question stems from the fact that I am writing a similar scalar matrix for another variable "T", which is not posing this issue. TEqn.H is attached and the matrix is shown below:
fvScalarMatrix TEqn
    fvm::ddt(rhoCp ,T)
    - isLiquid * fvm::laplacian(kLEff, T)
    - (1 - isLiquid) * fvm::laplacian(kVEff, T)
    isLiquid * fvc::laplacian(kLEff * DTField, isInterfaceOwnerLiquid)
    + (1 - isLiquid) * fvc::laplacian(kVEff * DTField, isInterfaceOwnerLiquid)
    - isLiquid * fvc::laplacian(kLEff * DTField, isInterfaceOwnerVapor)
    - (1 - isLiquid) * fvc::laplacian(kVEff * DTField, isInterfaceOwnerVapor)
Can someone help me with the reason why the faceFluxCorrection is not thrown for the TEqn but it happens for pEqn? Is there a way this multiplication can be done for the pEqn matrix as well.
Help is much needed and greatly appreciated.
Thanks.
File Type: h TEqn.H (847 Bytes, 2 views)
raunakbardia is offline   Reply With Quote
Old   January 10, 2020, 13:32
Default cannot scale a matrix containing a faceFluxCorrection
Vivek
vivek05 is on a distinguished road
Hi Raunak Bardia,
Did you find answer to your question?
Because I have same problem with scalar transport equation.
Any help would be appreciated.
Thanks
vivek05 is offline   Reply With Quote
fvm::laplacian, isoadvector, laplacian operator, peqn
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) Adam_K OpenFOAM Running, Solving & CFD 2 March 27, 2019 06:51
How can I get the number of elements per row form the matrix? klausb OpenFOAM Programming & Development 2 December 30, 2018 15:27
How to find a good time scale strategy? StefanG CFX 19 June 8, 2012 08:41
Force can not converge colopolo CFX 13 October 4, 2011 22:03
OpenFOAM version 1.6 details lakeat OpenFOAM Running, Solving & CFD 42 August 26, 2009 21:47
