November 18, 2019, 02:39 |
Problem in blockMesh for different z_length
Bidesh Sengupta
Rep Power: 7 |
Hi Foamers!
I am facing a strange problem while changing the height of the cylinder. I am proving the blockMeshDict file. //meshGenApp blockMesh; convertToMeters 1; dia 1.48; ll -2; lu 0; ori_x 0; ori_y 0; xdiv 30; ydiv 50; zdiv 60; sq_two 1.414; rb #calc "$dia/2"; nrb #calc "-1*$dia/2"; ra #calc "0.8*$dia/4"; nra #calc "0.8*-1*$dia/4"; b #calc "0.5*$dia/$sq_two"; nb #calc "-0.5*$dia/$sq_two"; a #calc "0.25*$dia/$sq_two"; na #calc "-0.25*$dia/$sq_two"; vertices ( //Plane A: ($a $na $ll)//(0.0643 -0.064 -2) // Vertex A0 = 0 (dia/sq_two -dia/sq_two) ($a $a $ll)//(0.0643 0.0643 -2) // Vertex A1 = 1 (dia/sq_two dia/sq_two) ($na $a $ll)//(-0.064 0.0643 -2) // Vertex A2 = 2 (-dia/sq_two dia/sq_two) ($na $na $ll)//(-0.064 -0.0643 -2) // Vertex A3 = 3 (-dia/sq_two -dia/sq_two) ($b $nb $ll)//(0.0919 -0.0919 -2) // Vertex A4 = 4 (0.5*dia/sq_two -0.5*dia/sq_two) ($b $b $ll)//(0.09192 0.0919 -2) // Vertex A5 = 5 (0.5*dia/sq_two 0.5*dia/sq_two) ($nb $b $ll)//(-0.09192 0.0919 -2) // Vertex A6 = 6 (-0.5*dia/sq_two 0.5*dia/sq_two) ($nb $nb $ll)//(-0.09192 -0.0919 -2) // Vertex A7 = 7 (-0.5*dia/sq_two -0.5*dia/sq_two) //Plane B: ($a $na $lu)//(0.0643 -0.064 0) // Vertex B0 = 8 ($a $a $lu)//(0.0643 0.0643 0) // Vertex B1 = 9 ($na $a $lu)//(-0.064 0.0643 0) // Vertex B2 = 10 ($na $na $lu)//(-0.064 -0.0643 0) // Vertex B3 = 11 ($b $nb $lu)//(0.0919 -0.0919 0) // Vertex B4 = 12 ($b $b $lu)//(0.09192 0.0919 0) // Vertex B5 = 13 ($nb $b $lu)//(-0.09192 0.0919 0) // Vertex B6 = 14 ($nb $nb $lu)//(-0.09192 -0.0919 0) // Vertex B7 = 15 ); // Defining blocks: blocks ( //Blocks betweenplane A and plane B: // block0 -positive x O-grid block hex (5 1 0 4 13 9 8 12 ) ($xdiv $ydiv $zdiv)simpleGrading (1 1 1) // block1 -positive y O-grid block hex (6 2 1 5 14 10 9 13 ) ($xdiv $ydiv $zdiv)simpleGrading (1 1 1) // block2 -negative x O-grid block hex (7 3 2 6 15 11 10 14 ) ($xdiv $ydiv $zdiv)simpleGrading (1 1 1) // block3 -negative y O-grid block hex (4 0 3 7 12 8 11 15 ) ($xdiv $ydiv $zdiv)simpleGrading (1 1 1) // block4 -central O-grid block hex (0 1 2 3 8 9 10 11 ) ($ydiv $ydiv $zdiv)simpleGrading (1 1 1) ); edges ( //Plane A: arc 0 1 ($ra 0 -2) arc 1 2 (0 $ra -2) arc 2 3 ($nra 0 -2) arc 3 0 (0 $nra -2) arc 4 5 ($rb 0 -2) arc 5 6 (0 $rb -2) arc 6 7 ($nrb 0 -2) arc 7 4 (0 $nrb -2) //Plane B: arc 8 9 ($ra 0 0) arc 9 10 (0 $ra 0) arc 10 11 ($nra 0 0) arc 11 8 (0 $nra 0) arc 12 13 ($rb 0 0) arc 13 14 (0 $rb 0) arc 14 15 ($nrb 0 0) arc 15 12 (0 $nrb 0) ); // Defining patches: patches ( patch inlet ( (1 5 4 0) (2 6 5 1) (3 7 6 2) (0 4 7 3) (3 2 1 0) ) patch outlet ( (13 9 8 12) (14 10 9 13) (15 11 10 14) (12 8 11 15) (8 9 10 11) ) wall wallDiffuser ( (4 5 13 12) (5 6 14 13) (6 7 15 14) (7 4 12 15) ) ); While ll=-2, the mesh (Fig1) is nice. But when I am trying with ll=-0.2, it (Fig2) is very strange. |
November 18, 2019, 19:40 |
Bidesh Sengupta
Rep Power: 7 |
The problem was solved by changing the arc with ll and lu.
Thank you. |
blockmesh, foam extend, openfaom |
[snappyHexMesh] Problem and doubts with blockMesh, snappyHexMesh and multiple geometry | luca1992 | OpenFOAM Meshing & Mesh Conversion | 0 | August 23, 2017 11:40 |
[blockMesh] BlockMesh problem | ari92 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2017 10:23 |
[blockMesh] blockMesh problem with wedge blocks | gned | OpenFOAM Meshing & Mesh Conversion | 0 | September 14, 2016 05:49 |
[blockMesh] Problem with blockMesh and my shape | TneurolF | OpenFOAM Meshing & Mesh Conversion | 4 | June 25, 2013 13:52 |
Blockmesh problem with more than one block | sven82 | OpenFOAM Pre-Processing | 1 | June 4, 2013 17:08 |
