Remote Access: Post-Processing - help!
Like Tree1Likes
  • 1 Post By hokhay
Old   August 2, 2020, 03:53
Default Remote Access: Post-Processing - help!
Mudit Mehta
Mudit2208 is on a distinguished road
Hello Foamers,
I am quite new to OpenFOAM. I ran a simulation for flow past a circular cylinder at Re = 3900 in some PC at other place (remote access). Now it is completed and i want to do post-processing and view paraView results in my laptop. I cannot copy the whole folder (including VTK) because the file sizes are so large.
Please feel free to ask any information if needed. Also, i tried searching it on internet but could not find any useful information. Kindly suggest if you have any.
Can someone help in this issue?
Thanks in advance
Mudit2208 is offline   Reply With Quote
Old   August 2, 2020, 08:16
Bazinga is on a distinguished road
Originally Posted by Mudit2208 View Post
Hello Foamers,
Thanks in advance
It depends what you want to observe in paraview. The minimum that is required is probably the 0, constant, system and last time directory when executing parafoam. You can also run it with the paraview command which requires less files but not sure exactly. Here you need to first create a dummy file that is loaded: "touch dummy.foam"
Bazinga is offline   Reply With Quote
Old   August 3, 2020, 04:16
hokhay is on a distinguished road
Hello Foamers,
Thanks in advance
Paraview supports post-processing on remote server.
1. Run 'pvserver' on the remote server
2. Open paraview on the local computer (your laptop)
3. Click 'Connect' in paraview
4. Click 'Add server'
5. Change the 'Host' to the IP address of the remote server
6. Click 'Configure' and connect the server
Mudit2208 likes this.
hokhay is offline   Reply With Quote
Old   August 4, 2020, 03:56
Mudit Mehta
Thank you so much for the help!
openfoam, paraview, remote access
post processing for CEL expressions Niru CFX 0 May 10, 2013 13:13
Automated post processing using CFD Post shreyasr ANSYS 0 January 28, 2013 06:21
CFD post processing techniques & streamlining klk Main CFD Forum 0 October 19, 2010 07:37
fluent for post processing James FLUENT 0 April 21, 2006 04:43
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 20:51
