Constructors in OpenFOAM
Like Tree3Likes
  • 2 Post By geth03
  • 1 Post By geth03
Old   November 18, 2020, 08:13
Default Constructors in OpenFOAM
user92 is on a distinguished road
Hello!
I appreciate any direct help with the topic below ... or a reference/guide/video which explains the full story for beginners
________________________________________________
my understanding of constructors in C++ is the following:
Class name (parameter list)
Member initializer list
{statement}
I tried to match with OpenFOAM using Lines 37 to 47 below from the code here
Foam:: prghPressureFvPatchScalarField::
const fvPatch& p,
const DimensionedField<scalar, volMesh>& iF
fixedValueFvPatchScalarField(p, iF),
rhoName_("rho"),
p_(p.size(), Zero)
My guess (please correct me if I'm wrong)
- Class name is prghPressureFvPatchScalarField
- fvPatch and DimensionedField<scalar, volMesh> are parameters and they were given aliases p and iF
my questions
- what is fixedValueFvPatchScalarField(p, iF)
- {} is empty, I'm not sure what the constructor is doing overall
- what is the first line Foam::X::X (I've seen this frequently in different codes)
Thank you
user92 is offline   Reply With Quote
Old   November 20, 2020, 04:39
geth03 is on a distinguished road
i commented the lines for you
Foam:: prghPressureFvPatchScalarField:: //Foam is the namespace :: yourClassName :: yourConstructorAsFunction
const fvPatch& p,
fixedValueFvPatchScalarField(p, iF), //your class inherits from this class, so
//this must be included, you cannot ignore
//the parent class, if multiple parents exist, do same for other parents
rhoName_("rho"), // next two lines overwrite attributes
p_(p.size(), Zero)
{} //you already overwrote attributes, so
// nothing to do for that class here,
// other classes might need it to do stuff
Reptider and user92 like this.
geth03 is offline   Reply With Quote
Old   November 20, 2020, 05:16
Thank you I have a few more clarifications if you don't mind
I'm used to seeing braces {} used with classes, so I wonder what would className() mean? what are p & iF in this case? are they arguments? objects?
p_(p.size(), Zero)
to make sure I understood this, can I generalize it as variablename_(update)
where the update could be a new name or some changes on how the variable is defined
Old   November 24, 2020, 08:46
i don't quite get what you mean by className(),
but let my clarify few things.
p and iF are arguments for the function fixedValueFvPatchScalarField,
fixedValueFvPatchScalarField(p, iF) is a parameter constructor bc it takes arguments to construct an instance. what p and iF mean you can look up and decipher from the code (p means pressure, don't know what iF means, didnt look it up, maybe initialField?).
if you have a constructor without an argument (maybe you mean that by className()) you can create instances from that class without providing input.
next point:
if you want to update an attribute automatically when creating an instance of a class you can do this like
rhoName_("rho") // so rhoName_-value will be updated with rho-value.
user92 likes this.
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
OpenFOAM Foundation Releases OpenFOAM v2.3.0 opencfd OpenFOAM Announcements from OpenFOAM Foundation 3 December 23, 2014 03:43
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
The OpenFOAM extensions project mbeaudoin OpenFOAM 16 October 9, 2007 09:33
