July 5, 2021, 21:35 |
Quasi-static multiphase flow?
Henri Sundelin
Rep Power: 4 |
As a part of my thesis work, I'm modeling a cavitating impeller in water. My thesis advisor recommended me to do a quasi-static investigation in STAR-CCM - but I'm wondering if that would be also feasible in OpenFOAM. In STAR-CCM, the plan is to model only one blade as a symmetric angular section. We'd need full multiphasic flow to see real effect - I've been investigating the interPhaseChangeFoam solver, if that could be somehow applied. We'd however need compressible flow in the gas phase for any accuracy though. I was wondering is this kind of approach feasible in OpenFOAM, or would I need to do a full unsteady simulation? |
July 6, 2021, 03:07 |
Cyprien
Rep Power: 18 |
local time step (LTS) is the keyword you are looking for. InterFoam has a LTS implementation.
Cheers, Cyprien
www.cypriensoulaine.com/openfoam |
July 6, 2021, 04:14 |
Henri Sundelin
Rep Power: 4 |
OK, that looks promising. But what about symmetry? We're symmetrical in cylinderical coordinates.
Optimally the whole solver should be in cylinderical coordinates - is that possible? |
July 6, 2021, 04:55 |
Rep Power: 8 |
openfoam uses cartesian coordinates
July 10, 2021, 17:25 |
Henri Sundelin
Rep Power: 4 |
Thanks, as my system has 6 blades it sounds like only half-plane symmetry would be usable, correct?
//HS |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
BC problem with Eulerian-Eulerian Multiphase Flow | ngoc_tran_bao | CFX | 4 | September 24, 2016 04:43 |
2 inlets with a different gas in each = a multiphase flow solver ? | adrieno | OpenFOAM Running, Solving & CFD | 2 | April 5, 2016 05:00 |
multiphase flow | leon_jar | CFX | 8 | November 4, 2015 02:06 |
pulsating static pressure around zero at pipe flow | David Kim | FLUENT | 0 | May 16, 2006 13:47 |
