refineMesh utility stops without any error
Old   August 26, 2021, 15:50
Default refineMesh utility stops without any error
Venkat Ganesh
Venky_94 is on a distinguished road
I've created a wedge geometry using blockMesh and am trying to use refineMesh utility to refine the mesh in x and y directions. The issue I'm facing is that the refineMesh utility stops without showing any error.
I came across a similar bug reported in 2013 (https://bugs.openfoam.org/view.php?id=746#bugnotes), but I couldn't quite understand the solution mentioned. I'd be really grateful if someone could take a look at it. I've tried using the utility standalone and also with refineMeshDict, they all give the same output.
I've attached the blockMeshDict, refineMeshDict, topoSetDict and logs of checkMesh and refineMesh. Please suggest.
Venky_94 is offline   Reply With Quote
refinemesh utility
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 06:25
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
