TVD schemes, questions about limitedLinear
Like Tree34Likes
Old   October 10, 2015, 14:09
Default TVD schemes, questions about limitedLinear
Davi Barreira
davibarreira is on a distinguished road
I've been reading about the numerical schemes in OpenFOAM, and I found (perhaps) some divergence concerning the TVD schemes and Sweby limiters.
In Dr. Jasak's thesis (pg 98), it says that:
\phi_f=\phi_{UD}+\psi(\phi_{HO}-\phi_{UD})
So for ψ = 1 we get a Higher Order scheme (central difference), while ψ = 0 we get Upwind.
The thing is, at OpenFOAM's website (http://cfd.direct/openfoam/user-guid...20-1140004.4.5), it is said that "Some TVD/NVD schemes require a coefficient ψ,0 ≤ ψ ≤ 1 where ψ = 1 corresponds to TVD conformance, usually giving best convergence and ψ = 0 corresponds to best accuracy". But doesn't that mean that for ψ = 0 we get the higher order (more accurate) and ψ = 1 we get less accurate (Upwind)? And isn't it the opposite of what is written in Dr. Jasak's thesis?
I expected that limitedLinear 0.5 would be the same as linearUpwind grad(U), but when I run the same case for these two schemes, the results are different.
Also, as stated in this thread (http://www.cfd-online.com/Forums/ope...tedlinear.html), I thought that limitedLinear 0 would be equal to upwind and limitedLinear 1 would be equal to linear, but it is not the case.
Did I understand thing in a wrong way, or is there an inconsistency? Also, should these schemes be indeed the same or not?
Thanks in advance.
Btw, sorry if this is posted in the wrong section of the forum. I saw that another similar thread was posted in this section, so I did the same.
davibarreira is offline   Reply With Quote
Old   October 12, 2015, 09:12
Bazinga is on a distinguished road
I can not really tell how it is implemented in OpenFOAM but I will try to have a look at it if I find the time.
If we use the equation of Jasak
We get Upwind for \psi= 0 but we would not get the CDS for a value of \psi= 1. I think we would need a \psi= 0.5 to get CDS using Jasak's equation.
In Versteeg and Malalasekra you will also find a section about TVD Schemes. Here the equation is:
\phi_e=\phi_{P}+\frac{1}{2}\psi(\phi_{E}-\phi_{P})
Now, we would get a CDS for \psi= 1.
Bazinga is offline   Reply With Quote
Old   October 12, 2015, 09:28
Davi Barreira
Indeed, I just checked Versteeg and Malalasekra, and it's like you said. Thanks for the correction.
Although, the problem remains, cause using limitedLinear 0 and limitedLinear 1, none of them is equal to Upwind (when comparing the results of the simulations).
Old   October 13, 2015, 09:21
Just a bit more information and a correction. Jasak's equation is actually the same as Versteeg's equation. I understood Jasak's naming convention wrong in my last reply:
Jasak:
Using Versteeg's naming convention and assuming that we take CDS for as the higher-order scheme (HO) we get:
\phi_f = \phi_e \; and \; \phi_{UD}=\phi_P \; and \; \phi_{HO} = \frac{\phi_P+ \phi_E}{2}
If you insert these in the first equation you get exactly Versteeg's equation:
Now my guess is that due to the implementation of the schemes in OpenFOAM the \psi that the user can choose is different from the \psi in the equations above. Thus making for example limitedLinear 0 not equal Upwind.
davibarreira likes this.
Old   October 13, 2015, 11:38
Davi Barreira
That's also what I thought, since the simulation results were not matching. I tried to take a look at the code, but couldn't understand it. The thing is, I'm using limitedLinear 1 for the convection term, but I dont know how appropriate it is, since I couldn't figure out the proper implementation of the limitedLinear scheme.
Old   October 14, 2015, 16:11
Joseph Urich
jurich is on a distinguished road
limitedLinear is used in fvSchemes as Gauss limitedLinear k
The value k you specify when activating the scheme is not the same as \psi, as used in Jasak's thesis.
What you get from limitedLinear is \psi(r) = r * \frac{2}{k}, with r as defined in Jasak's thesis, and \psi limited between 0 and 1.
See the discussion: http://www.cfd-online.com/Forums/ope...ar-scheme.html, and lines 76 and 95 of limitedLinear.H
So if you use k = 0, \psi will be fixed at 1.0, and you get the higher order scheme everywhere, in this case central differencing.
If you use k = 1, you get a limiter of \psi(r) = 2 * r applied. This limiter is the edge of Sweby's TVD region; it is TVD conforming.
That's why the documentation describes it that way.
JonW, tiam, Bazinga and 14 others like this.
jurich is offline   Reply With Quote
Old   October 14, 2015, 19:52
Davi Barreira
Thank you, Joseph. I read the thread and the code, and it is indeed as you pointed out. The only thing that I still dont get is why using Gauss linear is not giving me the same result as Gauss linearLimited 0, since both should be central diff.
I will keep on digging, but thanks again for your info.
Old   October 18, 2015, 16:52
cabrera is on a distinguished road
Hello Joseph and Davi,
I am also working with the limitedLinear scheme. I would be grateful if you could tell me if you agree with the following interpretation of the code.
The limiter \Psi is defined in limitedLinear.H to have the following limits (line 95)
0<= \Psi = 2r/k <=1
where 0<=k<=1 is introduced by the user. Therefore, the limitedLinear scheme is a TVD scheme ONLY when the user chose k=1 (\Psi = 2r). When the user choose whatever other value for k, the scheme does not full-fill the TVD condition, because then \Psi > 2r.
Then for k=1 the TVD condition is full-filled and stability is "assured" (within the limitations of the TVD schemes), but the accuracy depends on r. As r is a function of the gradients of \Psi it represents how convective the flow is. The more convection, the more upwinding is introduced and the accuracy decreases. For pure diffusive flows r=1 and the CD scheme is used, still fulfilling the TVD condition because k=1.
Do you agree?
Thank you very much!
Ana
Information about the TVD scheme can be found at Hrvoje Jasak PhD thesis.
Regions for a TVD second order scheme:
cabrera is offline   Reply With Quote
Old   October 19, 2015, 13:08
Davi Barreira
Yes, Ana. I have pretty much the same interpretation.
cabrera likes this.
Old   October 20, 2015, 10:04
Joseph Urich
Hello Ana,
I agree with your interpretation on TVD as well.
However, r is calculated as the ratio of upwind gradient to downwind gradient. Scalar version is given starting at line 95 of NVDTVD.H. It divides the gradient at cell center projected to the face (d & gradcP) by the difference between cell value and neighbor value of phi ( phiN - phiP ). So it is calculated as a function of the local values of phi only.
I don't think that's quite the same as your interpretation of diffusion vs. convective gradients.
cabrera likes this.
Old   October 22, 2015, 16:24
Eric Robertson
msuaeronautics is on a distinguished road
For what it's worth, I've studied the limitedLinear scheme in some detail for my Master's work. Important to me because it is my divergence scheme of choice for most OF simulations. I have some figures showing the behavior of several k values on a pure scalar convection problem.
I see this reflected in my results, where setting k to zero or a really small value still does not recover central differencing. Maybe I am missing something in the explanations given here that would reveal why this is. If anyone is interested in my results, I can dig through some figures and post them.
msuaeronautics is offline   Reply With Quote
Old   October 22, 2015, 16:42
Davi Barreira
Hey Eric, could you send a link to your Master thesis, so I can understand this scheme better.
Old   October 23, 2015, 10:22
Eric Robertson
Here is the link.
http://pqdtopen.proquest.com/doc/171...5.html?FMT=ABS
The scheme is only a minor part of the entire document, so I have included some supplemental figures as an attachment to this post, showing the setup of the test as well as some figures. I tested the convection of a step and a Gaussian profile. In the Gaussian, you can see that smaller values of k don't necessarily recover the original central difference (my nomenclature calls this UBCD).
I finished my Master's degree before I could dig any further. I believe I have also written a program to output the value of the Phi(r) limiter at every point based on its definition in the source code, which I will try to recover.
Old   October 27, 2015, 19:57
Davi Barreira
Great stuff, Eric. Havent finished, but it's already helping me.
msuaeronautics likes this.
Old   October 28, 2015, 11:31
Eric Robertson
Good to know. If you have any questions, don't hesitate to send me a message.
Old   November 5, 2015, 08:03
Question for a lid driven cavity, how to use tvd/nvd schemes for divergence schemes
  #16
narayana vekamulla
vnarayana is on a distinguished road
Hello every one,
how to apply TVD/NVD schmes for divergence schmes .
i tried the following.
in fvSchmes subfolder changed
divSchemes
default none;
div(phi,U) Gauss NVD schemes;
when i am running by using the command icoFoam i got the following error
narayana@narayana-Lenovo-G50-80 ~/OpenFOAM/narayana-2.4.0/run/tutorials/incompressible/icoFoam/cavity_nvd $ icoFoam/*---------------------------------------------------------------------------*\
| \\ / O peration | Version: 2.4.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.4.0-f0842aea0e77
Exec : icoFoam
Date : Nov 06 2015
Time : 05:55:30
Host : "narayana-Lenovo-G50-80"
PID : 5304
Case : /home/narayana/OpenFOAM/narayana-2.4.0/run/tutorials/incompressible/icoFoam/cavity_nvd
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Time = 0.0025
Courant Number mean: 0 max: 0
--> FOAM FATAL IO ERROR:
Unknown discretisation scheme TVD
Valid schemes are :
60
CoBlended
Gamma
GammaV
LUST
MUSCL
MUSCLV
Minmod
MinmodV
OSPRE
OSPREV
Phi
QUICK
QUICKV
SFCD
SFCDV
SuperBee
SuperBeeV
UMIST
UMISTV
biLinearFit
blended
clippedLinear
cubic
cubicUpwindFit
downwind
filteredLinear
filteredLinear2
filteredLinear2V
filteredLinear3
filteredLinear3V
fixedBlended
limitWith
limitedCubic
limitedCubicV
limitedLinear
limitedLinearV
limiterBlended
linear
linearFit
linearPureUpwindFit
linearUpwind
linearUpwindV
localBlended
localMax
localMin
midPoint
outletStabilised
pointLinear
quadraticFit
quadraticLinearFit
quadraticLinearUpwindFit
quadraticUpwindFit
reverseLinear
skewCorrected
upwind
vanAlbada
vanAlbadaV
vanLeer
vanLeerV
weighted
file: /home/narayana/OpenFOAM/narayana-2.4.0/run/tutorials/incompressible/icoFoam/cavity_nvd/system/fvSchemes.divSchemes.div(phi,U) at line 32.
From function surfaceInterpolationScheme<Type>::New(const fvMesh&, const surfaceScalarField&, Istream&)
in file lnInclude/surfaceInterpolationScheme.C at line 137.
FOAM exiting
I got answers for upwind,quikc schmes but not TVD/NVD i tried but i could not get it.
please help me .
vnarayana is offline   Reply With Quote
Old   November 5, 2015, 08:09
Davi Barreira
As the error message says, the way you are writing the scheme is wrong. As you must know, there are several TVD schemes (TVD is more like a class of schemes), so you must choose one. Some of them are the vanLeer, UMIDST, SuperBee... The one I'm using is the limitedLinearV 1, which is discussed in this thread. But you may try the vanLeer, which is better documented.
P.S: when you are using the divScheme of vectors, you might want to use vanLeerV, intead of vanLeer.
vnarayana likes this.
Old   November 5, 2015, 13:32
Cool for a lid driven cavity, how to use tvd/nvd schemes for divergence schemes
  #18
narayana vekamulla
Thank you very much. UMIDST not working.
Old   November 5, 2015, 14:22
Davi Barreira
Sorry, UMIST.
Old   November 6, 2015, 02:17
Smile for a lid driven cavity, how to use tvd/nvd schemes for divergence schemes
  #20
narayana vekamulla
Thank you Davi Barreira,
In NVD schemes, other than SFCD is there any other methods. Gamma and GammaV not working?
would you please send theory on TVD/NVD schemes .
where to get each method notes ? , how works in openfoam?
Thanks & Regards
narayan
A few simple questions about linearUpwind and limitedLinear chegdan OpenFOAM 28 March 30, 2024 02:44
Using TVD Schemes in fvScheme aydemirk OpenFOAM Pre-Processing 1 August 20, 2014 04:26
TVD schemes Vino Main CFD Forum 3 September 16, 2013 19:47
TVD schemes: 2 questions Shuo Main CFD Forum 0 August 19, 2008 21:51
TVD Schemes Matt Umbel Main CFD Forum 1 January 25, 2000 04:21
