How to run the case with #codeStream to generate the initial condition in fe41 |
Yang Xueliang
Rep Power: 4 ![]() |
Hi everyone!
Recently I was using codeStream to generate the initial conditions I wanted, but after using solids4foam &>log, I got the following result, where the log file ends with the is up to date. The detail is as follow. _97f89ca9e8c9e14ee938b417e0c5322af4cd6fc2/../platforms/linux64GccDPInt32Opt/lib/libcodeStream_97f89ca9e8c9e14ee938b417e0c5322af4cd 6fc2.so' is up to date. And the terminal shows segmentation fault (core dumped). I really want to know the operation flow of using codestream in foam-extend4.1. Is there any difference between it and other versions? What I use is that blockMesh first and then the solver solid4Foam & > log directly. But it doesn't seem to make computing work. Really hope you could give me some suggestions. Thanks ! Young |
codestream, foam extend 4.1, solids4foam |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
