[Commercial Meshers] Fluent to OpenFoam, parallel conversion |
November 17, 2021, 23:59 |
serg
Rep Power: 10 |
I have a fluent block mesh, which is quite large (around 400M) so I want to convert it using multiple processors, but there seems to be no parallel option for fluentMeshToFoam or fluent3DMeshToFoam. Is there any way to make it possible? Any help is appreciated. Thanks. |
July 28, 2023, 18:56 |
run fluent3DMeshToFoam in parallel processing
Rep Power: 10 |
Hi everyone,
I've been searching around this topic and found this question posted a while ago without any response solution to it. I'm currently in a similar situation. My mesh size is 10GB and my laptop cannot handle it or it takes very long. Just wondering if someone has done a parallel mesh conversion from fluent mesh to OpenFOAM? if there is a command please share as I couldn't find a clue in OpenFOAM wiki and elsewhere. |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 16:38 |
Can not run OpenFOAM in parallel in clusters, help! | ripperjack | OpenFOAM Running, Solving & CFD | 5 | May 6, 2014 15:25 |
[Commercial meshers] Error on mesh conversion from Fluent to openFoam | sam.ho | OpenFOAM Meshing & Mesh Conversion | 6 | February 21, 2014 00:12 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Something weird encountered when running OpenFOAM in parallel on multiple nodes | xpqiu | OpenFOAM Running, Solving & CFD | 2 | May 2, 2013 04:59 |
