Bounding Omega problems // Number of lambda iterations exceeds maxLambdaIter(10)
Old   March 7, 2022, 05:57
Default Bounding Omega problems // Number of lambda iterations exceeds maxLambdaIter(10)
Marie
Marie_Dal is on a distinguished road
Hello everyone,
I am new to OpenFoam. I am currently running a simulation of an airfoil using SimpleFoam with the turbulence model KomegaSST LM. After just a few iterations (4), the value of bounding omega (max) starts to be very high, which I believe is the reason why a warning appears a couple iterations after:
--> FOAM Warning :
From function Foam::tmp<Foam::DimensionedField<double, Foam::volMesh> > Foam::RASModels::kOmegaSSTLM<BasicMomentumTranspor tModel>::ReThetat0(const Internal&, const Internal&, const Internal&) const [with BasicMomentumTransportModel = Foam::IncompressibleMomentumTransportModel<Foam::k inematicTransportModel>; Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Internal = Foam::DimensionedField<double, Foam::volMesh>]
in file ../momentumTransportModels/lnInclude/kOmegaSSTLM.C at line 300
Now in my very little experience with this turbulence model, I believe this to be a boundary condition problem. I tried different values for omega, using wall functions for k, omega and nut, and also removing them, but nothing seems to work.
I tried turning my turbulence model back to the K omega SST, and the simulation runs without inconvenience, for which I assume the mesh is not the problem.
This is what an itertion with this warning looks like:
Time = 6
smoothSolver: Solving for Ux, Initial residual = 0.0493299, Final residual = 0.00422165, No Iterations 5
smoothSolver: Solving for Uy, Initial residual = 0.249744, Final residual = 0.0204515, No Iterations 4
GAMG: Solving for p, Initial residual = 0.107384, Final residual = 0.00826549, No Iterations 3
time step continuity errors : sum local = 0.000609625, global = -6.2441e-06, cumulative = -1.32525e-05
--> FOAM Warning :
smoothSolver: Solving for ReThetat, Initial residual = 0.0628862, Final residual = 0.00492529, No Iterations 5
smoothSolver: Solving for gammaInt, Initial residual = 0.00826379, Final residual = 0.000491998, No Iterations 4
bounding gammaInt, min: -0.0724182 max: 1.11402 average: 0.963246
smoothSolver: Solving for omega, Initial residual = 0.0155426, Final residual = 0.00154728, No Iterations 6
bounding omega, min: -112.337 max: 2.47547e+10 average: 1.1801e+06
smoothSolver: Solving for k, Initial residual = 0.998501, Final residual = 7.2704e-05, No Iterations 1
ExecutionTime = 6.61 s ClockTime = 7 s
An error finally comes up after 18 iterations, when everything has already diverged:
Time = 18
smoothSolver: Solving for Ux, Initial residual = 0.730684, Final residual = 3.77352e+08, No Iterations 10
smoothSolver: Solving for Uy, Initial residual = 0.658047, Final residual = 3.8716e+08, No Iterations 10
#0 Foam::error::printStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
#4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
#8 Foam::fvMatrix<double>::solve() in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
#9 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
I have faced very similar problems with other simulations, but changing boundary conditions (usually rising the value for omega) has always seemed to fix them. Yet, no matter what I try with this simulation, I can't seem to fix it.
I very much appreciate anyone's advice. I attach below boundary conditions and gradient schemes.
Thank you. :)
BOUNDARY CONDITIONS:
GammaInt:
internalField uniform 1;
boundaryField
{ inlet { type fixedValue;
value $internalField; }
outlet
{ type zeroGradient; }
walls
airfoil
frontAndBackPlanes
{ type empty; } }
K:
internalField uniform 0.00135;
boundaryField
{ inlet
{ type fixedValue;
value uniform 0.00135; }
outlet
airfoil
{ type fixedValue;
value uniform 1e-6; }
walls
frontAndBackPlanes
{ type empty; }}
nut
internalField uniform 0.0020125;
boundaryField
{ inlet { type freestream;
freestreamValue uniform 0.0020125; }
outlet { type freestream;
airfoil { type nutkWallFunction;
value uniform 0.00000020125; }
walls { type zeroGradient; }
frontAndBackPlanes { type empty; }}
OMEGA:
dimensions [0 0 -1 0 0 0 0];
internalField uniform 2.6708;
boundaryField
outlet { type zeroGradient; }
airfoil { type omegaWallFunction;
ReThetaT
internalField uniform 1170.563958;
boundaryField
airfoil { type zeroGradient; }
For U and P I use freeStream and no slip conditions on the airfoil, altough those boundary conditions are vastly tested and I am certain those are not the problem.
Marie_Dal is offline   Reply With Quote
Old   May 4, 2022, 20:47
Default Inquiry
Abdelrahman Kamaleldin
akamal1099 is on a distinguished road
Hello my friend
did you find a solution?? I am experiencing this problem now.
Thanks
akamal1099 is offline   Reply With Quote
Old   June 1, 2022, 06:34
Emily
em17 is on a distinguished road
Hi, I am also having the exact same error. Has anyone managed to fix it?
Thanks, Em
em17 is offline   Reply With Quote
Old   June 1, 2022, 06:53
I did manage to fix it.
  1. Don't take y+ to be 1. Instead, take it to be >30 so you can use wall function for turbulence quantities
  2. I setted the inlet and outlet in one group and called it freestream
  3. Make sure you have the right boundary conditions for ReTheta and Gamma. You can check in openfoam wiki
I will upload my boundary files. But again I tried a lot to do the analysis with y+ = 1 but I couldn't. Some experts told me it a mesh problem even thought my mesh was fine per checkMesh. But there point was that if you are solving a 2D problem (only one cell in z direction throughout the whole mesh), the solver will experience such issues. So, I worked with y+>30 and I used wall fucntions
Hope it help.
Thanks
Old   June 1, 2022, 06:54
Rest of files
Old   June 17, 2023, 22:06
TWB
quarkz is on a distinguished road
I have similar errors and my problem is an unsteady wing case in 3D.
For the bounding omega error, I change to:
Gauss linearUpwind default;
or
Gauss upwind;
For the maxLambdaIter error, my simulation continues to run w/o problem. But for subsequent simulations, I use:
kOmegaSSTLMCoeffs
maxLambdaIter 100;
You can give it a try to see if it works.
quarkz is offline   Reply With Quote
Old   July 17, 2023, 03:58
CFDUser29 is on a distinguished road
Also, it depends a lot on the conditions you impose.
For instance, if you do a quick sensibility study, you find that huge initial values for omega can bring erratic behavior to the residuals.
Also, it is interesting to look at the relaxation factor. For me, it is working well for 0.4 to 0.5, below it is too slow and add a lot of oscillations, and above (the value depends on the case you have), you can add bounding issues because you allow the solver to add a more important contributions for a given field in the equations where it contributes at each iteration.
CFDUser29 is offline   Reply With Quote
airfoil, komega sst model, komegasstlm
Help sought on axial compressor simulation jyotir OpenFOAM Running, Solving & CFD 0 November 17, 2021 10:49
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 17:36
Converging Diverging Nozzle with dbnsTurbFoam Saleh Abuhanieh OpenFOAM Running, Solving & CFD 4 December 13, 2019 10:26
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. Nkl OpenFOAM Running, Solving & CFD 19 October 10, 2019 02:42
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 14:05
