Flow inside a converging nozzle with Pimplefoam |
April 12, 2022, 04:33 |
badShinchan
Rep Power: 4 |
I am attaching the case file. Whenever i try to run, it shows the error.
(attached below) 277999892_1089769345204759_900859964713374417_n.jpg 277959553_2840606089574810_867235461933461332_n.jpg I tried to run the simulation with " mpirun -np 2 pimpleFoam -parallel " as I have decomposed 2 processors. no velocity is known. the inlet and outlet pressure are defined in the P file the 0/U /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type zeroGradient; } outlet { type zeroGradient; } wall { type fixedValue; value uniform (0 0 0); } } // ************************************************** *********************** // the 0/P /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type fixedValue; value uniform 101325; } outlet { type fixedValue; value uniform 86000; } wall { type zeroGradient; } } // ************************************************** *********************** // the controldict file /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application pimpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 1000; deltaT 0.2; writeControl timeStep; writeInterval 200; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; functions { #includeFunc fieldAverage(U, p, prime2Mean = yes) } // ****************** ************************************************** ***** // |
April 20, 2022, 15:14 |
MNM
Rep Power: 8 |
Hi nahian_masud,
Welcome to the forum. Hope u already solved the problem....If not, based on the limited info provided in the post......few suggestions 1) change the Code:
internalField uniform 0; Code:
internalField uniform 101325; 2) From the log file we can see the courant number is too high....maybe you can do checkMesh to see if everything is fine....If so, then you can start with smaller deltaT magnitudes....and then allow solver to choose the optimum deltaT based on maximum allowed Courant number....by adding following Code:
adjustTimeStep true; maxCo 1; Another kind suggestion :- From next time onwards, please try to ask the questions in the respective subsections of the forum...for ex : Meshing related things can be asked in https://www.cfd-online.com/Forums/openfoam-meshing/, case running & solving in (https://www.cfd-online.com/Forums/openfoam-solving/).....then your question will have more visibility and thus a faster response. Regards, Shubham |
Issues when simulating nozzle flow with outside region | blais.bruno | SU2 | 4 | March 13, 2024 14:04 |
Pressure drop across a converging nozzle | mjkey | CFX | 16 | July 17, 2019 13:22 |
Sonic flow for exhaust nozzle | beanlee999 | FLUENT | 1 | May 10, 2012 14:34 |
Modelling the Heat flow inside the curing oven | Marios Vlad | CFX | 1 | February 6, 2008 07:11 |
compressible flow in a counterflow nozzle | d.vamsidhar | FLUENT | 0 | November 24, 2005 01:45 |
