How to transfer the modified data in serial process to other processes? |
yunyu_wang
Rep Power: 0 ![]() |
Hello, everyone!
I recently encountered a problem. I need to insert a serial operation into parallel computing. And I used some functions in MPI to do it as the following codes. But I found that the modified data in serial process is not passed to other processes. So how can I make the modified data in the serial pass to other processes? Thank you! Code:
int main(int argc, char *argv[]) { int i(0); int numprocs; int myid; MPI_Status stat; MPI_Init(&argc, &argv); MPI_Comm_size(MPI_COMM_WORLD,&numprocs); MPI_Comm_rank(MPI_COMM_WORLD,&myid); // there is N data altogether in testNumber volScalarField testNumber ( IOobject ( "testNumber", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh ); if(myid==0) { for(i=0;i<N;i++) { testNumber[i]=i; } } testNumber.write(); // It is found that only the testNumber in the 0 process has been modified, //and the testNumber of other processes remains unchanged. } |
mpi, openfoam, serial in parallel |
modified version of timeVaryingMappedFixedValue BC for looping through data | syavash | OpenFOAM Programming & Development | 13 | November 3, 2023 18:38 |
Initializing transient analysis using static analysis in two-way FSI simulation | Daniel_Khazaei | ANSYS | 50 | September 12, 2017 10:56 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
post process to get an arbitrary face data | oniboy | Siemens | 2 | February 28, 2008 22:12 |
Data transfer | H. P. LIU | Main CFD Forum | 5 | May 19, 2003 10:47 |
