October 2, 2022, 03:07 |
Dynamic code Openfoam2206 WSL2
Huy Quang Dong
Rep Power: 8 |
Hi foamers!
On my windows desktop, i'm using WSL2 (Windows Subsystem for Linux 2) for running ubuntu 22.04.1 LTS (code name : jammy). After the installation of Openfoam2206, i've tested some tutorials and all the cases with Dynamic code did not work. By example with the tutorial "multiphase/overInterDyMFoam/twoSimpleRotors". Below is the output function with dynamic code (i didn't do any change) : alphaVol { libs (utilityFunctionObjects); type coded; name alphaVolume; writeControl timeStep; writeInterval 10; codeWrite #{ const volScalarField& alpha = mesh().lookupObject<volScalarField>("alpha.water") ; Info<< "Alpha volume = " << alpha.weightedAverage(mesh().Vsc()) << endl; #}; } When i run the tutorial, i had the following error : Using dynamicCode for functionObject alphaVol at line 92 in "/mnt/d/twoSimpleRotors/system/controlDict.functions.alphaVol" Could not load "/mnt/d/tCould not load "/mnt/d/twoSimpleRotorCould not load "/mnt/d/twoSimpleRotors/dynwoSimpleRotors/dynamicCode/plaamicCode/platforms/linux64GccDPInt32Opt/lib/libalphaVolumes/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libatforms/linux64GccDPInt32Opt/lib/libalphaVolume_4a024lphaVolume_4a02447a6_4a02447a6 0286e990b3a446b74d59547a60286e990b3a446b74d595c431 3b0286e990b3a446b74d595c4313b159c.so" /mnt/d/twoSimpleRotors/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libalphaVolume_4a02447a60286e990b3a446b74d595c4313 b159c.so: cannot open shared object file: No such file or directory 159c.so" /mnt/d/twoSimpleRotors/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libalphaVolume_4a02447a60286e990b3a446b74d595c4313 b159c.so: cannot open shared object file: No such file or directory c4313b159c.so" /mnt/d/twoSimpleRotors/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libalphaVolume_4a02447a60286e990b3a446b74d595c4313 b159c.so: cannot open shared object file: No such file or directory Creating new library in "dynamicCode/alphaVolume/platforms/linux64GccDPInt32Opt/lib/libalphaVolume_4a02447a60286e990b3a446b74d595c4313 b159c.so" Invoking wmake libso /mnt/d/twoSimpleRotors/dynamicCode/alphaVolume wmake libso /mnt/d/twoSimpleRotors/dynamicCode/alphaVolume [HC-2568-1:09302] 2 more processes have sent help message help-btl-vader.txt / cma-permission-denied [HC-2568-1:09302] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages ln: ./lnInclude dep: functionObjectTemplate.C Ctoo: functionObjectTemplate.C link: /mnt/d/twoSimpleRotors/dynamicCode/alphaVolume/../platforms/linux64GccDPInt32Opt/lib/libalphaVolume_4a02447a60286e990b3a446b74d595c4313 b159c.so For some reasons, the "make" has not been done successfully. Did i miss something during the installation? Many thanks for your help! |
October 2, 2022, 22:05 |
Tatsuya Shimizu
Rep Power: 13 |
Does dynamic code not work after installing the additional dependencies?
$ sudo apt install bison flex m4 build-essential |
October 3, 2022, 06:43 |
Huy Quang Dong
Rep Power: 8 |
Hi Longe!
I've install the addiontal dependencies but nothign works. I've even reinstall Wsl 2, ubuntu and openfoam but i have the same problem. |
October 3, 2022, 18:12 |
Tatsuya Shimizu
Rep Power: 13 |
Hi
It seems that the problem that is happening is a bit complicated. For example, what would happen if you build statically as follows? $ cd dynamicCode/alphaVol $ wmake libso To create dynamicCode/alphaVol, run Allrun once. |
October 4, 2022, 09:35 |
Huy Quang Dong
Rep Power: 8 |
Hi LongGe!
The error gone always with your solution Using dynamicCode for functionObject alphaVol at line 102 in "/mnt/d/twoSimpleRotors/system/controlDict.functions.alphaVol" Courant Number mean: 0 max: 0 Interface Courant Number mean: 0 max: 0 deltaT = 0.00117647058824 Time = 0.00117647 However i can not find the output file in postProcessing folder??? |
October 4, 2022, 11:35 |
Huy Quang Dong
Rep Power: 8 |
Hi LongGe!
Everything is ok now. I've found the output in the log file. I've forgotten the meaning of Info<< command. Thanks for your help! |
dynamic code, openfoam 2206, ubuntu 22.04.1, wsl2 |
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle | FelixJJ | FLUENT | 2 | October 20, 2021 02:39 |
[isoAdvector] Issues with modification of IsoAdvector Code | raunakbardia | OpenFOAM Community Contributions | 16 | September 4, 2020 05:36 |
The FOAM Documentation Project - SHUT-DOWN | holger_marschall | OpenFOAM | 242 | March 7, 2013 12:30 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
What is the Better Way to Do CFD? | John C. Chien | Main CFD Forum | 54 | April 23, 2001 08:10 |
