November 8, 2022, 12:05 |
Construct2D mesh in OpenFoam
Stefano Segneri
Rep Power: 4 |
I am having problems trying to use the Construct2D C-mesh in OpenFoam. I have already read all the threads about this topic but I am still having problems. This is the procedure I follow: - C-mesh generation with Construct2D - Conversion to .msh format using p3d2gmsh - I use GmshToFoam to convert the .msh mesh in OpenFoam format In this way in the file polyMesh/boundary there will be the following boundaries: - b8-SYMMETRY-Y --> FRONT - b9-SYMMETRY-Y --> BACK - b6-FARFIELD --> OUTLET - b7-FARFIELD --> OUTLET - b5-FARFIELD --> INLET - b4-VISCOUS --> AIRFOIL - B2-to-stitch-a --> WAKE - defaultFaces --> WAKE defaultFaces and B2-to-stitch-a are exactly the same thing (WAKE) as I am able to see from Paraview. The boundary "WAKE" is a boundary that connect the airfoil trailing edge with the outlet. Obviously, it is an undesired boundary: air should just flow freely and without constraints there. To remove this boundary I use the following command: "stitchMesh -overwrite WAKE defaultFaces". After that, in the polyMesh/boundary file, B2-to-stitch-a and defaultFaces has zero faces. Thus, I just remove them and run my simulation. However, in that exact point, something very strange happens in the velocity field. I am attaching a picture. Does anyone knows how to fix this? Thanks to everyone who have had the patience to read this post. |
openfoam mesh construct2d |
Tool to convert OpenFoam mesh to SU2 mesh (2D and 3D) | Combas | SU2 | 44 | March 12, 2024 00:35 |
[Salome] Script for converting a mesh from Salome-Platform to OpenFOAM | nsf | OpenFOAM Meshing & Mesh Conversion | 86 | February 8, 2023 10:30 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
[Salome] Mesh conversion Salome to OpenFOAM | VMartinez | OpenFOAM Meshing & Mesh Conversion | 11 | April 21, 2014 02:54 |
