how to extract the LES filter delta in creatField.H
Old   December 8, 2012, 15:37
Post how to extract the LES filter delta in creatField.H
hz283 is on a distinguished road
Hi All,
I am using rhoPimpleFoam and LES Smagorinsky model. The filter width delta is used in the simulation. Now I would like to use delta() to output another quantity (it is volScalarField type), and I think I can add somes lines in creatFields.H. However, I had some problems about how to use the fileter delta () in createFields.H of rhoPimpleFoam. Delta is calculated in LESModel.H. Does anybody have any experience about this problem? Thank you very much.
hz283 is offline   Reply With Quote
Old   November 22, 2022, 14:30
Sandeep
Sandeep lamba is on a distinguished road
Hi hz283,
Could you resolve the issue. Actually I am facing same issue. Can you please guide how to access LESDelta.
Kind Regards
Sandeep
Sandeep lamba is offline   Reply With Quote
how can use the LES filter? (laplace filter and anistropic filter) ethan oh OpenFOAM Running, Solving & CFD 11 December 26, 2018 02:37
Bugs in LES filter codes yekaniyasari OpenFOAM Bugs 4 February 19, 2018 06:51
LES Filter in Smagorinsky model on inhomogenous grids Ivan Main CFD Forum 1 October 25, 2012 11:30
calculation of test filter quantites for desired parameters(equations) in les mrn FLUENT 0 July 15, 2010 05:04
LES with different filter Rick Main CFD Forum 1 August 22, 2008 18:10
