turbulentInlet boundary with time-dependent flow velocity
Like Tree1Likes
  • 1 Post By Chris T
Old   March 23, 2023, 16:09
Question turbulentInlet boundary with time-dependent flow velocity
hui cheng
chenghui62000 is on a distinguished road
Hi all,
I would like to do a LES simulation for a tidal current (with a 5% turbulence intensity). The tidal current will go from 0.25 m/s and to -0.25 m/s ("-" means opposite direction).
I tried use the turbulentInlet type inlet condition, and find that this type seems not support time-dependent velocity input.
I tried like this:
    left
        type               turbulentInlet;
        fluctuationScale  (0.05 0.05 0.05);
        referenceField    uniformValue table
          ((0 (0.25 0 0))
          (10800 (0.0 0 0))
           (21600 (-0.25 0 0))
It gives errors as:
--> FOAM FATAL IO ERROR: (openfoam-2012)
Expected keyword 'uniform' or 'nonuniform', found uniformValue
Could anyone give me some advice for this kind of simulations?
Best regards,
H
chenghui62000 is offline   Reply With Quote
Old   April 3, 2023, 11:09
Chris
Chris T is on a distinguished road
This sounds like something that code stream might be able to do.
There is a good tutorial on how to do similar things in of9 in this video tutorial series (see section 7) https://invidious.snopyta.org/playli...mDChejiwm846Wl. Here is the same playlist here if you prefer the Youtube website https://www.youtube.com/playlist?lis...mDChejiwm846Wl.
In the website for these tutorial you can also find the examples shown in the videos such that you can copy-paste and edit the to suit your problem.
chenghui62000 likes this.
Chris T is offline   Reply With Quote
inlet bc, les, time-dependent, turbulentinlet
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 05:53
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
Postprocess: sampleDict works but creates no output folder shock77 OpenFOAM Post-Processing 14 November 15, 2021 08:27
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 11:19
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
