From function Foam::scalar Foam::janafThermo<EquationOfState>:: |
March 23, 2023, 11:33 |
Prakash Bhattarai
I am repeatedly encountered with the same error From function Foam::scalar Foam::janafThermo<EquationOfState>::limit(Foam::sc alar) const [with EquationOfState = Foam:erfectGas<Foam::specie>; Foam::scalar = double] in file /home/ubuntu/OpenFOAM/OpenFOAM-10/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 117 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 3500; T = -248.737 min/max(T) = 200, 3500 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/buoyantReactingFoam" #8 Foam::fvMatrix<double>::solve() in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/buoyantReactingFoam" #9 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/buoyantReactingFoam" #10 ? in "/lib/x86_64-linux-gnu/libc.so.6" #11 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #12 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/buoyantReactingFoam I am currently trying to simulate hydrogen leak for the dispersion in a forced-type ventilated room. I have attached the link of the files with this message. I am eagerly waiting for suggestions. Thank you in advance. https://drive.google.com/drive/folde...JN?usp=sharing |
August 8, 2023, 05:01 |
harshavardhan
Rep Power: 8 |
your temperature is out of range. please check the boundary conditions.
buoyantreactingfoam, openfoam 10 |
Calculating source term total cell-zone volume parallel computation | RobV | Fluent UDF and Scheme Programming | 2 | May 30, 2022 03:46 |
Install/compile fireFoam 1.6-1.0 in Openfoam 2.1.1 | hz283 | OpenFOAM Programming & Development | 19 | April 1, 2013 08:35 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
LiftDrag coefficient in LES | fabian_korn | OpenFOAM Post-Processing | 1 | September 22, 2008 02:34 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
