Current state of conjugate heat transfer in OpenFOAM |
June 26, 2017, 14:16 |
Marc
Rep Power: 9 |
I wanted to start a threat to discuss about the present state of conjugate heat transfer solvers in OpenFOAM.
Recently I have been trying to carry out a research project based on cht and in reviewing literature I have found this:http://www.tfd.chalmers.se/~hani/kur...eport_Turo.pdf Here, the author clearly states that cht solvers in OpenFOAM are considerably worse than other commercial options in terms of convergence speed. Furthermore, in the OpenFOAM.org funding article (https://openfoam.org/news/funding-2017/) they explicitly mention that "Heat transfer, including conjugate heat transfer (CHT)" require "significant code refactoring and/or rewriting" and will be addressed in upcoming versions. With this said, do you believe that state of cht codes are good enough to invest time and effort into serious research in conjugate heat transfer using OpenFOAM? Thank you for your opinions. |
June 27, 2017, 06:15 |
#2 | |
Juho Peltola
Rep Power: 17 |
April 4, 2023, 13:47 |
Rep Power: 12 |
Any views from users who have compared the latest different OpenFOAM branches?
My beginner's take on the state of things so far, which could be outdated:
Integrated conjugate heat transfer solver in OpenFOAM | hjasak | OpenFOAM Running, Solving & CFD | 172 | April 13, 2023 00:42 |
Thermal non-equilibrium porous media model with conjugate heat transfer | Hexahedron | FLUENT | 9 | February 22, 2023 02:55 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 02:54 |
