Can LES models used for 2D or axisymmetric in OpenFOAM |
April 6, 2023, 12:39 |
Ching Liu
Rep Power: 8 |
I want to do a simulation using Large Eddy Simulation (LES) in OpenFOAM.
The geometry is axisymmetric. I found online that LES is only suitable for 3-D cases, but not appropriate for reduced-dimension cases. So I am wondering if LES models can be used for axisymmetric cases in OpenFOAM? |
January 16, 2024, 07:52 |
JuanMi
Rep Power: 8 |
January 16, 2024, 12:43 |
You really just repeated the info that the original poster had already written ... perhaps more useful would be an explanation. The reason why you cannot run LES (or DNS) in less than 3D is that LES is aiming to resolve and simulate directly the large turbulent scales of motion, and to do that you need 3 dimensions since all* turbulence is 3D in nature.
*Okay - let's dance around the edge of the rabbit hole - in very exceptional circumstances, you can have 2D turbulence ... but only in geophysical types of flow (i.e. thin layers with large horizontal lengthscale), in the presence of Coriolis effects and density stratification which inhibit motion in the 3rd dimension. Carry on down the hole if you're interested in more info! |
January 16, 2024, 13:17 |
JuanMi
Rep Power: 8 |
Sorry for not being able to give such an elaborate answer as yours.
I have limited myself to answering the question posed by the user in the title of the post. I don't think my answer was useless enough to reproach me. Regards |
January 17, 2024, 04:01 |
Apologies if my response felt like a reproach - it was not intended so; careless phrasing on my part. Best regards, T
axisymmetric, les, openfoam |
Computational effort of various LES models | velkon | Main CFD Forum | 10 | November 11, 2021 09:30 |
breakup and collision models OpenFOAM | Rid@foam | OpenFOAM | 1 | December 30, 2020 10:46 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 03:19 |
Comparison of axisymmetric case, Starccm+ and OpenFOAM | linnemann | OpenFOAM Running, Solving & CFD | 12 | June 16, 2011 05:43 |
Convertation axisymmetric cases from Fluent to OpenFOAM | Svensson | OpenFOAM | 0 | April 19, 2011 06:08 |
