snappyHexMesh Feature line extraction is only valid on closed manifold surfaces |
Lorenzo
Rep Power: 0 ![]() |
Hi everyone!
I'm trying to use snappyHexMesh to investigate the flow across a cilinder, with its axis parallel to the fluid flow. The blockMesh command works fine, but when I apply the surfaceFeatures step, it gives me this error: /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 10 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 10-c4cf895ad8fa Exec : surfaceFeatures Date : Apr 12 2023 Time : 00:40:46 Host : "lome-VirtualBox" PID : 6034 I/O : uncollated Case : /home/lome/Desktop/prove_surfacefeatures/MissileSenzaAlette2022/Prova1 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Reading "surfaceFeaturesDict" Surface : "missile_senza_alette.stl" Feature line extraction is only valid on closed manifold surfaces. fatal flex scanner internal error--no action found I can't understand from the last two lines how to solve the problem. Thank you for your help!! Lorenzo |
#blockmesh, #surfacefeaures |
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM | Ancioi | OpenFOAM Meshing & Mesh Conversion | 17 | January 8, 2019 23:50 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
[blockMesh] BlockMeshmergePatchPairs polyTopoChanger | benru | OpenFOAM Meshing & Mesh Conversion | 3 | June 29, 2008 21:24 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
