July 17, 2023, 03:29 |
Two species in one phase with two inlets
Rep Power: 2 |
Hello everyone,
I have searched a bit, but I didn't find a solution, so I hope one can help. I try to simulate dispersion of methane in air, given that I work in molar fraction (mol^-1). The case is the following : Inlet 1 : Air, mol_frac = 1 Inlet 2 : Air, mol_frac = 0.92 & CH4, mol_frac = 0.08 Of course I also impose conditions on speed as well as the turbulent kinetic energy. I guess that to do what I want, I can simply create two dictionaries called "Air" and "CH4" but I would like to tell the solver the density of both gases, but I don't know how to do that. Perhaps in Physical Properties. If I add two species in Physical Properties, do I have to change the viscosity model that is defined as below ? Code:
viscosityModel constant; nu [0 2 -1 0 0 0 0] 1.42e-5; |
July 17, 2023, 06:02 |
Yann
Rep Power: 26 |
You cannot do this with simpleFoam, a better approach would be to use reactingFoam (without reactions) which will do just what you are trying to achieve. It will allow you to define multiple species, each one having its own thermophysicalProperties. Cheers, Yann |
July 17, 2023, 06:07 |
Rep Power: 2 |
I will try it and tell you if that works. Thanks
definition, density, dispersion, species mixing |
UDF Species of each phase | U1990 | ANSYS | 3 | April 9, 2021 06:11 |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
iteration questions in discrete phase | iknowjesus | FLUENT | 4 | March 13, 2015 06:07 |
Three Phase flow into a reservoir... | akjha | Main CFD Forum | 0 | December 15, 2014 07:01 |
Species Transport model Vs discrete phase | Karthick | FLUENT | 0 | April 27, 2004 02:23 |
