Issue with Defining Slice Sub-Region for fieldAverage Function
Old   August 12, 2023, 14:18
Default Issue with Defining Slice Sub-Region for fieldAverage Function
Julio
Julio9919 is on a distinguished road
I'm encountering an issue while trying to define a slice sub-region for the fieldAverage function in OpenFOAM. I've followed the documentation closely but keep encountering an error message. I'm hoping someone can provide insights into what might be going wrong.
Problem Description: I'm attempting to use the fieldAverage function in OpenFOAM to calculate field averages within a specific slice sub-region. Here's the configuration I've used in my system/controlDict file:
fieldAverage
    type            fieldAverage;
    libs            ("libfieldFunctionObjects.so");
    enabled         true;
    writeControl    timeStep;
    writeInterval   20;
    subRegion samples.yNormal;
    fields
        U
            mean            on;
            prime2Mean      on;
            base            time;
        p
            mean            on;
            prime2Mean      on;
            base            time;
samples
    type            surfaces;
    libs            (sampling);
    //${_visualization};
    fields          (p U);
    surfaceFormat   vtk;
    verbose         false;
    writeInterval     20;
    interpolationScheme cellPoint;
    surfaces
        yNormal
            type            cuttingPlane;
            planeType       pointAndNormal;
            interpolate     true;
            store           true;
            pointAndNormalDict
                point   (0 0 0);
                normal  (0 1 0);
Issue: Upon running the simulation, I receive an error message indicating that the subRegion "slice" cannot be located. I'm wondering if there's something I might be missing or misunderstanding in the setup.
--> FOAM Warning :
From virtual const Foam:: objectRegistry& Foam::functionObjects::regionFunctionObject:: obr() const
in file db/functionObjects/regionFunctionObject/regionFunctionObject.C at line 63
Could not locate subRegion "slice"
Julio9919 is offline   Reply With Quote
fieldaverage, slice, subregion
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 10:51
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 06:27
