August 19, 2023, 12:59 |
Transonic flow over a supercritical airfoil
Areen Raj
Hello, I am trying to simulate the phenomena of transonic buffet over a supercritical airfoil - NASA SC(2)-0714. The shock boundary layer interactions in the flow lead to an oscillating lift and drag coefficient along with shock wave oscillation.
I'm using the NACA 0012 transonic tutorial as the starting point (same schemes and solution file). The mesh is pretty resolved, as calculating the y+ for the flow gives a max value of 4.1. The K Omega SST model is being utilized. The flow has Re = 2.8x10^6, Ma = 0.77 and alpha = 7 degree. At the beginning of the simulation, a few cycles of the shock takes place but soon the flow becomes steady and the force coefficients stabilize. I'm using the following paper as reference which shows continuously oscillating shock and coefficients - https://doi.org/10.1016/j.proeng.2013.03.123 Is this phenomena supposed to happen and am I misinterpreting the results in the paper? Or is there a problem with my simulation itself? |
buffeting, transonic aircraft, turbulence |
Is recirculating flow is free vortex or forced vortex? | FluidKo | Main CFD Forum | 11 | July 21, 2022 06:21 |
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 06:04 |
High drag for airfoil compared to XFOIL and wind tunnel data | Ry10 | SU2 | 15 | October 30, 2016 17:27 |
Boundary conditions for flow in nozzle | kgevers | FLUENT | 0 | July 26, 2015 12:46 |
How to model suction flow in an airfoil in Fluent | Davy | FLUENT | 4 | October 23, 2006 03:56 |
