error in createBaffles -overwirte after blockMesh and snappyHexMesh
Old   September 19, 2023, 07:45
Default error in createBaffles -overwirte after blockMesh and snappyHexMesh
Alberto Campuzano
baezacaljo is on a distinguished road
Good night dear all i am facing an error when i apply the createBaffles -overwirte command. But let me explain
i created my geometry in salome shaper in four parts, inlet.stl, inlet_pipe.slt, plate.stl and outlet.stl, then i applied the following commands:
surfaceFeatures
blockMesh
snappyHexMesh -overwrite
Then i open the boundary file located in polyMesh folder and i deleted the defaultPatch and instead of having 5 i change it to 4.
Then i apply the setFields and finally the createBaffles -overwirte in here is when problem arises
--> FOAM FATAL ERROR:
Problem : Patch inlet starts at 700821
Current face counter at 466735
Are patches in incremental order?
It seems in the boundary file because i deleted the defualtPatch, but if i do not delete such a patch, i will get an error as well.
i already tried to change the blockMesh and the snappyHexMesh but i have no success.
hence, do you any idea how to solve it?
finally i am using openFoam11
baezacaljo is offline   Reply With Quote
Old   September 19, 2023, 17:54
Alberto Campuzano
I found the problem, in snappyHexMesh the typeInfo needs to be specified.
Now one problem Solved
blockmesh, boundary, openfoam 11, snappy hex mesh
SnappyHexMesh with Empty patches in blockMesh Magistrane OpenFOAM Running, Solving & CFD 1 May 6, 2022 07:29
[blockMesh] blockMesh | MergePatchPairs | snappyHexMesh |Different number of cells in divisions pythag0ra5 OpenFOAM Meshing & Mesh Conversion 1 September 19, 2020 14:38
[snappyHexMesh] Cylindrical blockmesh to Improve snappyHexMesh Results nicholas.jones OpenFOAM Meshing & Mesh Conversion 3 May 16, 2019 09:52
[Gmsh] gMsh instead of blockMesh for base mesh, then snappyHexMesh sazabi2001 OpenFOAM Meshing & Mesh Conversion 0 February 23, 2017 12:00
