known pressure-inlet velocity calculated needed
Like Tree1Likes
  • 1 Post By Yann
Old   February 23, 2024, 05:24
Default known pressure-inlet velocity calculated needed
Zomzzz is on a distinguished road
Hi
i am using simple foam and i am not that expert in open foam
the situation which i have now, that i have inlet which has known pressure
and for velocity boundary i want to have something like this
inlet
{ type fixedvalue
value ( calculated calculated 0) }
but the problem that simplefoam doesn't understand calculated
so is there any way to use the pressure inlet as given to open foam and then tell open foam to calculate inlet velocity based on pressure and fix this calculated value for all time steps and iteration.
Zomzzz is offline   Reply With Quote
Old   February 26, 2024, 03:17
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Probably you can use the pressureInletOutletVelocity boundary condition.
Regards,
Tom
tomf is offline   Reply With Quote
Old   February 26, 2024, 03:31
i think it is not exactly what i want because in pressureInletOutletVelocity boundary i will need to define both pressure and velocity values
i want just to define pressure values and velocity at inlet will be calculated based on that pressure value
Old   February 26, 2024, 03:54
Yann
Yann will become famous soon enough
No need to specify a velocity with pressureInletOutletVelocity
Cheers,
Yann
Yann is offline   Reply With Quote
Old   February 26, 2024, 03:56
but i see in the guide that there is field for velocity:
<patchName>
type pressureInletOutletVelocity;
tangentialVelocity <field value>;
value <field value>;
// Optional entries
phi phi;
and regarding this boundary where it should be exactly located in p file or u file ?
and it is valid for simplefome ?
Old   February 26, 2024, 04:04
Yann
The tangential velocity parameter is optional: https://doc.openfoam.com/2312/tools/...utletVelocity/
This is a boundary condition for the U variable, and you can indeed use it with simpleFoam.
AtoHM likes this.
Old   February 26, 2024, 04:17
okay so i define in the u file that the inlet is pressureInletOutletVelocity
like this:
inlet
// Mandatory entries
and in p file i define the pressure of the in the inlet, correct ?
and last question, i want this inlet velocity to be as fixed value, so i want openfoam to calculate the velocity for the first time based on pressure and fix this calculated value for all simulation, will the pressureInletOutletVelocity do that ?
Old   February 26, 2024, 04:32
Yann
like this:
inlet
Correct.
No, it will compute velocity at each timestep. You can't fix both velocity and pressure anyway.
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 12:23
kindly help me .. i have and error at line number 147.. m zubair Fluent UDF and Scheme Programming 0 February 10, 2019 11:25
UDF comilation error. urgent help please m zubair Fluent UDF and Scheme Programming 4 February 10, 2019 11:19
Adjuting oulet pressure till inlet pressure reaches a certain value in timestep pvpnrao OpenFOAM Running, Solving & CFD 2 September 11, 2018 10:14
How to set up the inlet boundary condition for a low pressure case? beastieboys6 FLUENT 3 April 10, 2012 22:46
