Floating point exception (8)
Old   February 26, 2024, 10:43
Default Floating point exception (8)
francedisab is on a distinguished road
Hello!
I'm trying to run a simulation with the pimpleFoam solver but even if I change the time step or the max Courant number, it always stops at the 9th iteration with a long message, mentioning 'floating point exeption (8)'.
I don't understand what's the problem. Here's the message:
[1] #0  Foam::error::printStack(Foam::Ostream&) in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
[1] #1  Foam::sigFpe::sigHandler(int) in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
[1] #2  ? in /lib/x86_64-linux-gnu/libc.so.6
[1] #3  ? in /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi3/mca_op_avx.so
[1] #4  ? in /lib/x86_64-linux-gnu/libmpi.so.40
[1] #5  ompi_coll_base_allreduce_intra_recursivedoubling in /lib/x86_64-linux-gnu/libmpi.so.40
[1] #6  ompi_coll_tuned_allreduce_intra_dec_fixed in /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi3/mca_coll_tuned.so
[1] #7  PMPI_Allreduce in /lib/x86_64-linux-gnu/libmpi.so.40
[1] #8  ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/sys-openmpi/libPstream.so
[1] #9  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
[1] #10  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
[1] #11  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
[1] #12  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so
[1] #13  ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so
[1] #14  Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so
[1] #15  ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/pimpleFoam
[1] #16  ? in /lib/x86_64-linux-gnu/libc.so.6
[1] #17  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
[1] #18  ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/pimpleFoam
[Francesca:08630] *** Process received signal ***
[Francesca:08630] Signal: Floating point exception (8)
[Francesca:08630] Signal code:  (-6)
[Francesca:08630] Failing at address: 0x3e8000021b6
[Francesca:08630] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f80209ff520]
[Francesca:08630] [ 1] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7f8020a539fc]
[Francesca:08630] [ 2] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7f80209ff476]
[Francesca:08630] [ 3] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f80209ff520]
[Francesca:08630] [ 4] /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi3/mca_op_avx.so(+0x40b5)[0x7f801c0eb0b5]
[Francesca:08630] [ 5] /lib/x86_64-linux-gnu/libmpi.so.40(+0x33fb9)[0x7f801ee4cfb9]
[Francesca:08630] [ 6] /lib/x86_64-linux-gnu/libmpi.so.40(ompi_coll_base_allreduce_intra_recursivedoubling+0x6a8)[0x7f801eec3778]
[Francesca:08630] [ 7] /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi3/mca_coll_tuned.so(ompi_coll_tuned_allreduce_intra_dec_fixed+0x4f)[0x7f8016a9529f]
[Francesca:08630] [ 8] /lib/x86_64-linux-gnu/libmpi.so.40(PMPI_Allreduce+0x133)[0x7f801ee7c553]
[Francesca:08630] [ 9] /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/sys-openmpi/libPstream.so(+0x12972)[0x7f80209af972]
[Francesca:08630] [10] /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5scaleERNS_5FieldIdEES3_RKNS_9lduMatrixERKNS_10FieldFieldIS1_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKS2_h+0x148)[0x7f8021369328]
[Francesca:08630] [11] /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_S9_S9_RNS1_IS8_EESD_h+0x778)[0x7f802136db58]
[Francesca:08630] [12] /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x499)[0x7f802136e989]
[Francesca:08630] [13] /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x463)[0x7f8023a538f3]
[Francesca:08630] [14] /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(+0x4c769e)[0x7f802360769e]
[Francesca:08630] [15] /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixIdEERKNS_10dictionaryE+0x28)[0x7f80235f6f08]
[Francesca:08630] [16] pimpleFoam(+0x1cc39)[0x55dfad65bc39]
[Francesca:08630] [17] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7f80209e6d90]
[Francesca:08630] [18] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7f80209e6e40]
[Francesca:08630] [19] pimpleFoam(+0x23b75)[0x55dfad662b75]
[Francesca:08630] *** End of error message ***
Could someone help me?
Thanks!
francedisab is offline   Reply With Quote
Old   February 27, 2024, 13:46
ask
askques123 is on a distinguished road
Originally Posted by francedisab View Post
Hello!
Thanks!
Hi I am facing a similar issue. I am modelling Giesekus multimode Turbulence model and simulation is running for few time steps and then I am getting Floating point error. Did you find a solutionn or can someone Resolve this
askques123 is offline   Reply With Quote
Old   February 28, 2024, 03:20
No, I still don't know the solution. Hope someone can help us
Old   February 28, 2024, 12:08
I think the problem should be the definition of the courant number in controlDict. Try to change it according to your mesh and time step and see if it works!
Regards,
Francesca
floatingpointexception, pimplefoam
icoFoam floating point exception (8) leizhao512 OpenFOAM Running, Solving & CFD 7 November 1, 2018 11:43
A floating point exception has occurred: floating point exception [Overflow]. starlight STAR-CCM+ 4 May 4, 2016 09:08
A floating point exception - SEM Model yansheng STAR-CCM+ 1 April 4, 2016 04:57
Floating point exception from twoPhaseEulerFoam openfoammaofnepo OpenFOAM Running, Solving & CFD 1 March 19, 2016 13:56
Floating point exception (core dumped) for GAMG solver yuhou1989 OpenFOAM Running, Solving & CFD 2 March 24, 2015 19:28
