p equation error when restart calculation
Old   March 6, 2024, 08:23
Question p equation error when restart calculation
wlz
6120217 is on a distinguished road
When I use an FGM solver in OpenFOAM to calculate an LES case, I found that if I calculate without interrupting, the result will be right. But whenever I restart the calculation from my latest result, the p equation will be extremely strange from the first iteration and the initial residual will be close to 1. I am very certain that the p feild of the result I restart calculation from has no problem.
I am very confused about this situation. I will appreciate it very much if someone can help me haddle this problem.
I attach a txt containing part of my output file.
6120217 is offline   Reply With Quote
Old   March 6, 2024, 08:28
wlz
If there is a need to view my case or solver, I will upload them.
Old   March 6, 2024, 09:07
wlz
here is my fvscheme file
ddtSchemes
default backward;
gradSchemes
default cellLimited Gauss linear 1;
grad(U) cellLimited Gauss linear 1;
divSchemes
default none;
div(phi,U) Gauss linearUpwindV grad(U);
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div((nuEff*dev(T(grad(U))))) Gauss linear;
//added for FGMFoam:
div(phi,Z) Gauss upwind;
div(phi,PV) Gauss upwind;
div(phi,varZ) Gauss upwind;
div(phi,varPV) Gauss upwind;
div(phi,K) Gauss upwind;
div(phi,Yi_h) Gauss limitedLinear 1;
div(phi,nuTilda) Gauss limitedLinear 1;
div((muEff*dev2(T(grad(U))))) Gauss linear;
div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
div(phid,p) Gauss limitedLinear 1;
laplacianSchemes
default Gauss linear limited 1;
interpolationSchemes
default linear;
snGradSchemes
default limited1;
fluxRequired
default no;
p;
and fvSolution file
solvers
"(rho|rhoFinal)"
solver smoothSolver;
smoother GaussSeidel;
tolerance 1e-7;
relTol 0;
nSweeps 1;
p
solver GAMG;
tolerance 1e-8;
relTol 0.1;
cacheAgglomeration true;
nCellsInCoarsestLevel 10;
agglomerator faceAreaPair;
mergeLevels 1;
pFinal
$p;
tolerance 1e-8;
relTol 0;
pd
solver PCG;
preconditioner DIC;
tolerance 1e-8;
relTol 0;
pdFinal
$p;
tolerance 1e-8;
relTol 0;
"(U|h|Z|PV|k|epsilon|varZ|varPV)"
solver PBiCG;
preconditioner DILU;
tolerance 1e-7;
relTol 0.01;
"(U|h|Z|PV|k|epsilon|varZ|varPV)Final"
$U;
relTol 0;
Yi
$hFinal;
Old   March 12, 2024, 12:59
Tobermory will become famous soon enough
Hmmm ... it looks like the normalisation factor has changed on restart (remember that all of the residuals are normalised - refer to https://doc.cfd.direct/notes/cfd-gen...x130-166004r11). Not sure why this is happening, but it is occurring on just the first PIMPLE iteration, so shouldn't affect your solution ...
Tobermory is offline   Reply With Quote
G equation set up MadMaggot CONVERGE 2 August 16, 2023 03:18
Time-accurate solution restart from steady state solution jyotir SU2 6 December 8, 2021 08:34
How to continue calculation in ANSYS Workbench with System Coupling after unsave WangYihuHRB Fluent Multiphase 0 March 30, 2021 10:50
Viscosity and the Energy Equation Rich Main CFD Forum 0 December 16, 2009 14:01
Warning 097- AB Siemens 6 November 15, 2004 04:41
