How to calculate relative velocities in impeller |
April 3, 2024, 04:38 |
Pedro Gouveia
Rep Power: 3 |
Hey everyone.
As a part of my Master's Thesis, I am performing a steady state MRF analysis in OpenFOAM V11. I want to compare the CFD data I retrieved with the experimental one on the paper. They have these plots of tangential and axial relative velocities and I don't know how I can obtain these values from openfoam. I know this has to do with the velocities triangles, but I don't know how I can perform this calculation: - c = u + w, where c is absolute velocity, u is circumferencial velocity and w is relative velocity. - now I need w_r and w_theta. How can I convert these in openfoam? Or maybe apply a formula in paraview calculator? I saw this function called fieldCoordinateSystemTransform, but I can't manage to use it. Should I put it in the control dict? Or create a file for it in the system folder? Preferably I would like to perform these transformations as a postprocessing and not in-run process, since I already have the simulations. Thank you very much, Pedro Gouveia |
April 3, 2024, 06:15 |
#2 | |
Pedro Gouveia
Rep Power: 3 |
Hey guys, I just found out how to get the cylindrical velocities, at least for incompressible Fluid, in OpenFOAM v11. I don't know if it's the most correct way, but it's the only one I discovered. Put this line of code in the control dict, in the functions part: Code:
#includeFunc fieldAverage(cylindrical(U)) |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 09:10 |
How can I calculate the Relative Reynolds Number in DPM? | Xin | FLUENT | 0 | January 19, 2021 07:45 |
Calculating change in Relative Humidity | Usama1034 | Main CFD Forum | 1 | January 16, 2020 10:14 |
calculate velocity difference | helly | OpenFOAM Post-Processing | 0 | June 21, 2016 08:49 |
multiphaseInterFoam relative velocities and forces | Martin_K_lalelu | OpenFOAM Running, Solving & CFD | 0 | June 12, 2014 08:16 |
