How to add equations to modular solver in openFoam11
Old   September 11, 2023, 19:09
Default How to add equations to modular solver in openFoam11
Alberto Campuzano
baezacaljo is on a distinguished road
Dear All
I am looking for help, how to add temperature equation or any other equation to InterFoam solver?, i noticed, that now everything is called modular solver and even the name changed to incompressibleVoF.
i know everything is with classes, however, openFoam is improving faster and now i am a bit lost.
Finally the version is OpenFoam11
thanks in advance
baezacaljo is offline   Reply With Quote
Old   September 12, 2023, 00:09
Tatsuya Shimizu
LongGe is on a distinguished road
Hello baezacaljo
I would add to the class method "thermophysicalPredictor" in "incompressibleVoF.C".
The solver "foamRun" always calls this class method.
OpenFOAM-11/applications/modules/incompressibleVoF
void Foam::solvers::incompressibleVoF::thermophysicalPredictor()
OpenFOAM-11/applications/solvers/foamRun/foamRun.C
        // PIMPLE corrector loop
        while (pimple.loop())
            solver.moveMesh();
            solver.fvModels().correct();
            solver.prePredictor();
            solver.momentumPredictor();
            solver.thermophysicalPredictor();
            solver.pressureCorrector();
            solver.postCorrector();
Our Work: https://www.idaj.co.jp/product/ennovacfd/openfoam_gui/
Powered by Ennova : https://ennova-cfd.com/
Ennova's Channel Partners : http://www.wolfdynamics.com/
LongGe is offline   Reply With Quote
Old   September 12, 2023, 05:41
Alberto Campuzano
Thank you for your help LongGe
Now I assume I have to copy both folder the one called incompressibleVoF and compile it. And the other other one that contains the solver foamRun.C and compile it, right?
Finally in the controlDict file in solver I have to write myFoamRun, right?
By the way, i was reading the code carefully and the fie incompressibleVoF.C already has
void Foam::solvers::incompressibleVoF::thermophysicalPr edictor() {}
and the file incompressibleVoF.H has
// Member Functions //- Called at the start of the PIMPLE loop virtual void prePredictor(); //- Construct and solve the energy equation, // convert to temperature // and update thermophysical and transport properties virtual void thermophysicalPredictor();
Hence, i am not getting the code.
is the incompressibleVoF.C and foamRun considering the temperature already?
Best regards
Last edited by baezacaljo; September 12, 2023 at 09:38. Reason: lack of information
Old   September 12, 2023, 18:34
Tatsuya Shimizu
Hello
Since "foamRun" is simply a client using the "solver" class, you do not need to make any changes. All you have to do is copy "incompressibleVoF" and create your "yourincompressibleVoF". The controlDict is as follows.
application     foamRun;
solver          yourincompressibleVoF
foamRun" always calls the class method "thermophysicalPredictor()". This is as I have shown before. The following is the inheritance relation of the "incompressibleVoF" class. The "thermophysicalPredictor" is declared as a pure virtual function in the "fluidSolver" class.
incompressibleVoF->twoPhaseVoFSolver->twoPhaseSolver->VoFSolver->fluidSolver
virtual void thermophysicalPredictor() = 0;
The class "incompressibleVoF" must implement "thermophysicalPredictor", but "incompressibleVoF" does not solve the temperature, so its implementation is empty. And you will be the one to specifically do this implementation.
Old   September 13, 2023, 19:33
Alberto Campuzano
Thank you LongGe
So rry for the late reply i was testing and writing the code, look this is what i achieved so far (see attached files), however, in the case of the Make folder and the other two folder, do i have to modify them and then COMPILE THEM? or what to do?
i only modify the folder name from incompressibleVoF to incompressibleVoFTemp and the files stick with the same name incompressibleVoF.C and incompressibleVoF.H but with some modifications.
Thanks in advance
Old   September 13, 2023, 20:13
Tatsuya Shimizu
Hello
You will need to create a new class. I don't think you can just copy it.
For example:
class incompressibleVoFTemp
    public twoPhaseVoFSolver
    //- Runtime type information
    TypeName("incompressibleVoFTemp");
Other changes will need to be made to ctor and dtor as well....
Old   May 3, 2024, 09:42
K.C. is on a distinguished road
I found this thread via Google and have to admit, that I am facing the same problem.
I copied an existing solver module, modified it and then compiled it into an shared library with .so extension via "wclean" and "wmake libso".
Compilation worked fine, but my new solver class is not available to foamRun
I tried
foamRun -solver {nameOfMyOwnSolver}
while the .so was declared inside of my controlDict with
libs("{pathToMyLibrary.so}");
and I also tried
foamRun -libs '("{pathToMyLibrary.so}")' -solver {nameOfMyOwnSolver}
and my last attempt was to extend the searchPath for libraries with
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/{absolutePathToMyLibraryFolder}
In all ways foamRun complains with "solvers table is empty"
So how can I declare to foamRun to use my new created solver module?
The
Kind regards,
K.C.
K.C. is offline   Reply With Quote
incompressiblevof, interfoam, modular solver, openfoam 11
Add mesh refinement to solidDisplacementFoam solver j-avdeev OpenFOAM Programming & Development 0 May 10, 2022 12:39
Error SIGSEGV using VOF and UDF JERC_UTFSM Fluent UDF and Scheme Programming 14 November 7, 2021 23:17
Add a pollutant in simpleFoam solver Gohu8 OpenFOAM Running, Solving & CFD 2 July 19, 2017 03:16
How to add temperature to cavitatingFoam solver chodki-c OpenFOAM 9 September 30, 2010 11:21
Navier-stokes equations and iterative solver?? wuliang Main CFD Forum 2 January 13, 2003 22:28
