srinath
Rep Power: 17 ![]() |
Hello
I find the following quite puzzling. In icoFoam.C, i find the foll. lines solve(UEqn == -fvc::grad(p)); // --- PISO loop for (int corr=0; corr<nCorr; corr++) { volScalarField rUA = 1.0/UEqn.A(); U = rUA*UEqn.H(); ...... } Solving UEqn presumably changes the value of U. But what is the point if couple of lines later, we store rUA*Ueqn.H() in U If solving UEqn is a predictor for a U value, what is the point if we never use the value and overwrite it? I would appreciate it if someone could clarify this as i find it quite puzzling. Regards Srinath p.s. commenting out the solve UEqn line, seems to give visually acceptable results for the cavity case, but diff says the results are different. So clearly it is not a bug, but is doing something quite subtle |
Fabian Peng Karrholm
Thank you for your question. This gives me an excellent opportunity to advertise my thesis. This exact question is covered in Appendix A. The thesis main topic is diesel spray simulations using OpenFOAM, as well as simulation of cavitating flow in a model injector. However, since I have pondered on questions similar to the one you put out during my PhD studies, I put it as an appendix for myself to read, should I ever forget what happens in icoFoam. A free version is available at: http://powerlab.fsb.hr/ped/kturbo/Op...olmPhD2008.pdf If you want a paper copy, contact me by email. /Fabian |
srinath
Thanks Fabian
Appendix A in your thesis was very useful. Am also reading the rest of it as it is very interesting. Cheers Srinath |
Suresh kumar Kannan
Hello, Fabian
My name is Suresh. I have just stārted using OpenFOAM a few weeks back. I saw your thesis, your work seems to be quiet interesting. I would like to let you know that My P.hD research work is also similar to your topic. I amalso using OpenFOAM to study the break up of a liquid sheet from a nozzle. But a major part of my research work will include Nonlinear instability analysis of the liquid sheet. I am using lesInterFOAM of OpenFOAM v1.5 to do these simulations and I have already performed one simulation on a simple geometry. Since I have just started using OpenFOAM, i have a few basic questions and I hope you wouldnt mind answering them: 1) I found that the icoFOAM, interFOAM, lesInterfOAM are segregated solvers based on the PISO algorithm, just correct me if i am wrong in understanding .(with VOF for surface tracking and LES for turbulence modeling) 2) But I found in your thesis that you are including the compressibility effects, isnt it advicable to solve the equations in a coupled manner like in a coupled solver to solve a compressible fluid problem. 3) I also have a very basic question, is there any coupled solver in OpenFOAM? I have some experience in developing a coupled solver, so i understand the structure of a coupled solver. I also have some idea about the basic methodology of a segeregated solver as explained in basic textbooks by S.V.Patankar and Malalkasera. 4) For my simulations in OpenFOAM I have a setup like injecting 200bar pressure fluid into the chamber with 10bar pressure. This is just a test case given to me by Delphi. bye thanks for your reply inadvance with regards K.Suresh kumar |
1) Yes, to find an example of a solver that's not PISO, look at simpleFoam. 2) Perhaps it might be suitable, and there are quite a few coupled solver codes out there now, but PISO works fine for compressible flow (in my experience). 3) Not as far as I know, no. I think to develop a coupled solver in OpenFOAM you would have to dig into the source code much further than the top-level code. /Fabian |
Suresh kumar Kannan
Hello Fabian,
Thankyou very much for your reply. I will have a look at simpleFoam. But for my problem I dont have to worry about the coupled solver as my problem corresponds to an incompressible fluid. I was just curious to know more about the solver. I just have one more question can you provide me some reference on the algorithm and some details about the lesInterFOAM solver, if you have any? thankyou very much for reply bye K.Suresh kumar |
IcoFoam | aap | OpenFOAM Running, Solving & CFD | 15 | May 28, 2012 08:30 |
Density in icoFoam Densidad en icoFoam | manuel | OpenFOAM Running, Solving & CFD | 8 | September 22, 2010 04:10 |
About phi in icoFoam | kar | OpenFOAM Running, Solving & CFD | 3 | February 20, 2008 05:20 |
Possible bug in icoFoam | msrinath80 | OpenFOAM Bugs | 6 | November 19, 2007 17:35 |
IcoFoam on AIX 53 | ds2taieb | OpenFOAM Installation | 1 | March 24, 2006 03:22 |
