Error whit foamDataToFluent
Like Tree1Likes
  • 1 Post By Harikrishnan
Old   February 7, 2008, 04:32
Default Hi, I read the post present i
matteo_gautero
I read the post present in
http://www.cfd-online.com/OpenFOAM_D...es/1/1212.html
and for the mesh there is no problem, but if I try to use foamDataToFluent I obtain an error:
--> FOAM FATAL IO ERROR : cannot open file
file: /home/gauta/OpenFOAM-prebin/gauta-1.4.1/run/tutorials/simpleFoam/Socata_lam/syst em/foamDataToFluentDict at line 0.
From function regIOobject::readStream(const word&)
in file db/regIOobject/regIOobjectRead.C at line 66.
Any suggestion?
Thanks in advance,
Matteo.
Old   November 12, 2012, 04:46
Default foamDataToFluent
Harikrishnan G
Harikrishnan is on a distinguished road
copy the foamDataToFluentDict to the system sub-directory and then edit the contolDict and finally run the utility.....u will get the answer.
vcvedant likes this.
Harikrishnan is offline   Reply With Quote
FoamDataToFluent maritozzo OpenFOAM Post-Processing 34 December 14, 2020 12:33
FoamDataToFluent dnomdec OpenFOAM Post-Processing 8 July 31, 2013 11:07
Display Yplus whit porous medium in Star_cd Miotto Aurelien Siemens 1 December 18, 2008 15:35
I need help whit a error and heat transfer.. Victor FLUENT 1 September 4, 2007 09:29
Turbulent viscosity ratio whit sails javier FLUENT 0 February 2, 2004 11:48
