Would like local doxygen search form to work
Old   January 1, 2008, 15:19
Default Hi, I don't know if this ac
unoder
I don't know if this actually is the right place to ask, but I guess its relevant to somebody here, so here we go: I would like to be able to browse the doxygen documentation while offline and not connected to the internet.
However, when I type something in the "search field" I get a "Opening search.php" form up saying that this file is a PHP script. Then Firefox asks me what it should do with it.
I guess I should install something for the PHP scripting to work offline - php server? I'm running opensuse 10.0 (or 10.1?). Perhaps I can use yast?
Just tell me what I should download and try to install, and I'll try to make it work.
TIA,
Regards,
Martin
Old   January 2, 2008, 04:30
Default Hi Martin! The "easiest" wa
Assistant Moderator
Bernhard Gschaider
Hi Martin!
The "easiest" way to browse offline on your machine (in my experienve) is to install a webserver with php, make the doxygen-directory accessible to it and point your webbrowser to http://127.0.0.1/path_to_doxy
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   January 3, 2008, 06:36
Default Hi Bernhard, Thanks a lot f
unoder
Hi Bernhard,
Thanks a lot for the idea. The webserver now works for a very simple "index.html" file in /srv/www/htdocs/index.html (simply saying: "This works").
However, I currently got a problem with my apache configuration files I think - get an annoying "403 error - missing permission", but I think I'll solve that problem...
I see I need to change my DocumentRoot in /etc/apache2/default-server.conf and point it to the OpenFOAM/doc/Doxygen-directory (hmmm. or perhaps xxxx/Doxygen/html-directory, where the index.html file is)...
I hope I get it working... If anyone tried it, please tell how you modified your .conf-files in /etc/apache2. Or perhaps I'll figure it out myself, when I get a bit more time to google for an answer to the 403-error...
Regards,
Martin
Old   February 2, 2008, 20:56
Default Hi, In case anyone wants to
unoder
In case anyone wants to save some time and browse the documentation offline: I had a problem with Doxygen linking to C source files which it couldn't find so three steps were necessary to get a satisfactory behaviour:
1) I added a symbolic link in ~/OpenFOAM/OpenFOAM-1.4.1-dev/doc/Doxygen/html to
/home/martin/OpenFOAM/OpenFOAM-1.4.1-dev/src, which then makes the relative paths work by apache.
2) The content type of the C-source files were recognized as "text/C source file" so whenever I clicked on a source file, firefox asked me what to do with the file (download / save as etc.). The fix: "AddType text/plain C c CPP cpp"
3) Then the usual documentroot/directory settings must be right. Here's my "default-server.conf" file (suggestions and improvements are welcome - I don't know much about apache, but this seem to work nice locally - "Options FollowSymLinks" must be enabled for everything to work):
DocumentRoot "/home/martin/OpenFOAM/OpenFOAM-1.4.1-dev/doc/Doxygen/html"
<directory>
# Possible values for the Options directive are "None", "All",
# or any combination of:
# Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
# Note that "MultiViews" must be named *explicitly* --- "Options All"
# doesn't give it to you.
# The Options directive is both complicated and important. Please see
# http://httpd.apache.org/docs-2.2/mod/core.html#options
# for more information.
# AllowOverride controls what directives may be placed in .htaccess files.
# It can be "All", "None", or any combination of the keywords:
# Options FileInfo AuthConfig Limit
AllowOverride None
# Controls who can get stuff from this server.
Order allow,deny
Allow from all
</directory>
# -- MARTINS MODIFICATION: THINK OF SOURCE FILES AS --
# -- TEXT/PLAIN OR TEXT/HTML TO AVOID DOWNLOADING THEM --
# NOT SURE IF THIS IS NEEDED????
<ifmodule>
# Note that the name of the user directory ("public_html") cannot simply be
# changed here, since it is a compile time setting. The apache package
# would have to be rebuilt. You could work around by deleting
# /usr/sbin/suexec, but then all scripts from the directories would be
# executed with the UID of the webserver.
UserDir public_html
# The actual configuration of the directory is in
# /etc/apache2/mod_userdir.conf.
Include /etc/apache2/mod_userdir.conf
</ifmodule>
# Include all *.conf files from /etc/apache2/conf.d/.
# This is mostly meant as a place for other RPM packages to drop in their
# configuration snippet.
# You can comment this out here if you want those bits include only in a
# certain virtual host, but not here.
Include /etc/apache2/conf.d/*.conf
# The manual... if it is installed ('?' means it won't complain)
Include /etc/apache2/conf.d/apache2-manual?conf
ServerName laptop
ServerAdmin root@laptop
And the search-form / php-part works really great... Suse YAST-installer did everything for me (php5). Hope somebody can use the "recipe" (and else I might use it next time I forgot what I did and need to reinstall).
Old   February 4, 2008, 08:04
Default Hi Martin! Could you add th
Assistant Moderator
Bernhard Gschaider
Hi Martin!
Could you add this in the HowTo-secion of the Wiki? That would be great
Bernhard
Old   February 4, 2008, 17:07
Default Sure Bernhard, I suppose yo
unoder
Sure Bernhard,
I suppose you meant to add it here?
http://openfoamwiki.net/index.php/Main_HowTos
And here's the link:
http://openfoamwiki.net/index.php/Ho..._while_offline
If anyone get trouble/suggestions/improvements/thinks it should somewhere else in the wiki-tree, please edit the wiki-entry... I don't pretend to be an expert here...
Collabaration diagrams in Doxygen srinath OpenFOAM 3 November 10, 2011 01:35
SEARCH A PROOF FOR DERIVING DIFF. FORM OF CL CFDUser Main CFD Forum 17 March 7, 2009 03:03
Using Doxygen shuo OpenFOAM Running, Solving & CFD 1 October 3, 2006 03:39
Doxygen and dot Kuan Tek Seang (Seang) OpenFOAM Installation 1 January 25, 2005 04:24
why my In-Form doesn't work? green Phoenics 2 May 27, 2004 21:03
