Problems with simulating TurbFOAM
Old   July 13, 2009, 09:52
Default Problems with simulating TurbFOAM
Barath Ezhilan
barath.ezhilan is on a distinguished road
Hi All,
I am trying to simulate swirling flow in the draft tube of the turbine using KOmegaSST turbulence model with TurbFOAM and I am having a problem with it. The simulations stops after a few time steps. I have a delta T 1e-5 and I have also tried increasing the number of correctors and orthogonal correctors etc. The Mesh is fine, checkMesh says the Mesh is OK. I have also checked the boundary files
The log file:::
Time = 9.55556e-05
Courant Number mean: 0.00131032 max: 7.52485 velocity magnitude: 260.087
PBiCG: Solving for Ux, Initial residual = 0.104884, Final residual = 0.00497614, No Iterations 2
PBiCG: Solving for Uy, Initial residual = 0.110647, Final residual = 0.00209042, No Iterations 2
PBiCG: Solving for Uz, Initial residual = 0.0109506, Final residual = 0.000402031, No Iterations 2
PCG: Solving for p, Initial residual = 0.905193, Final residual = 0.00849971, No Iterations 19
time step continuity errors : sum local = 3.95906e-06, global = 2.96857e-08, cumulative = 2.60243e-07
PCG: Solving for p, Initial residual = 0.903698, Final residual = 0.0077981, No Iterations 21
time step continuity errors : sum local = 5.59011e-06, global = 2.96251e-08, cumulative = 2.89868e-07
PBiCG: Solving for omega, Initial residual = 0.0521617, Final residual = 0.00171759, No Iterations 2
bounding omega, min: -3.10703e+06 max: 1.37457e+07 average: 6537.53
PBiCG: Solving for k, Initial residual = 0.0759318, Final residual = 0.00116278, No Iterations 2
bounding k, min: -0.228331 max: 4.29478 average: 0.0111114
ExecutionTime = 293.4 s ClockTime = 295 s
Time = 0.000105556
Courant Number mean: 0.00177524 max: 16.8808 velocity magnitude: 532.235
PBiCG: Solving for Ux, Initial residual = 0.207847, Final residual = 0.0171767, No Iterations 2
PBiCG: Solving for Uy, Initial residual = 0.230103, Final residual = 0.0131825, No Iterations 2
PBiCG: Solving for Uz, Initial residual = 0.0368306, Final residual = 0.00168079, No Iterations 2
PCG: Solving for p, Initial residual = 0.905287, Final residual = 0.00834842, No Iterations 24
time step continuity errors : sum local = 7.86545e-06, global = 3.42434e-08, cumulative = 3.24111e-07
PCG: Solving for p, Initial residual = 0.909423, Final residual = 0.00750422, No Iterations 24
time step continuity errors : sum local = 1.0548e-05, global = 3.40615e-08, cumulative = 3.58173e-07
PBiCG: Solving for omega, Initial residual = 0.0586053, Final residual = 0.00481685, No Iterations 2
bounding omega, min: -1.3806e+07 max: 2.58179e+07 average: 13489.3
PBiCG: Solving for k, Initial residual = 0.0920886, Final residual = 0.00343743, No Iterations 2
bounding k, min: -1.52212 max: 6.6377 average: 0.0125395
ExecutionTime = 307.73 s ClockTime = 309 s
Time = 0.000115556
Courant Number mean: 0.00234709 max: 21.606 velocity magnitude: 748.857
PBiCG: Solving for Ux, Initial residual = 0.344634, Final residual = 0.0099675, No Iterations 3
PBiCG: Solving for Uy, Initial residual = 0.329588, Final residual = 0.0101443, No Iterations 3
PBiCG: Solving for Uz, Initial residual = 0.0829345, Final residual = 0.00185229, No Iterations 3
PCG: Solving for p, Initial residual = 0.894228, Final residual = 0.0069595, No Iterations 77
time step continuity errors : sum local = 1.32459e-05, global = 3.74457e-08, cumulative = 3.95619e-07
PCG: Solving for p, Initial residual = 0.941143, Final residual = 0.00818695, No Iterations 100
time step continuity errors : sum local = 4.97055e-05, global = 3.5411e-08, cumulative = 4.3103e-07
PBiCG: Solving for omega, Initial residual = 1, Final residual = 0.0738547, No Iterations 76
bounding omega, min: -1.39421e+19 max: 2.83497e+19 average: 8.33634e+14
PBiCG: Solving for k, Initial residual = 0.929398, Final residual = 2.79674e-11, No Iterations 1
bounding k, min: -1.05884 max: 9.29845 average: 0.00995458
ExecutionTime = 347.03 s ClockTime = 349 s
Time = 0.000125556
Courant Number mean: 0.0842083 max: 107356 velocity magnitude: 6.87564e+06
PBiCG: Solving for Ux, Initial residual = 0.999926, Final residual = 5.05889, No Iterations 1000
PBiCG: Solving for Uy, Initial residual = 0.999817, Final residual = 15.8907, No Iterations 1000
PBiCG: Solving for Uz, Initial residual = 0.999843, Final residual = 6.45841, No Iterations 1000
PCG: Solving for p, Initial residual = 0.999999, Final residual = 0.415433, No Iterations 1000
time step continuity errors : sum local = 6410.55, global = 3.66894e-08, cumulative = 4.67719e-07
PCG: Solving for p, Initial residual = 0.996811, Final residual = 0.317644, No Iterations 1000
time step continuity errors : sum local = 1.70248e+06, global = 3.65351e-08, cumulative = 5.04254e-07
The files in the system folder are given below
ControlDict::::
application turbFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 0.3;
deltaT 0.00005;
writeControl timeStep;
writeInterval 50;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression compressed;
timeFormat general;
timePrecision 6;
runTimeModifiable no;
// libs ("libaddedIncompressibleRASModels.so");
libs ("libOpenFoamTurbo.so" );
Schemes File::
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss limitedLinearV 1;
div(phi,k) Gauss limitedLinear 1;
div(phi,epsilon) Gauss limitedLinear 1;
div(phi,omega) Gauss limitedLinear 1;
div(phi,R) Gauss limitedLinear 1;
div(R) Gauss linear;
div(phi,nuTilda) Gauss limitedLinear 1;
div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DomegaEff,omega) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
Solution File::
solvers
p PCG
preconditioner DIC;
tolerance 1e-06;
relTol 0.01;
U PBiCG
preconditioner DILU;
tolerance 1e-05;
relTol 0.1;
k PBiCG
tolerance 1e-05;
relTol 0.1;
epsilon PBiCG
tolerance 1e-05;
relTol 0.1;
omega PBiCG
tolerance 1e-05;
relTol 0.1;
R PBiCG
tolerance 1e-05;
relTol 0.1;
nuTilda PBiCG
tolerance 1e-05;
relTol 0.1;
PISO
nCorrectors 4;
nNonOrthogonalCorrectors 2;
pRefCell 0;
pRefValue 0;
Please do help me this regard as to what I can do to solve this problem???
barath.ezhilan is offline   Reply With Quote
Old   July 14, 2009, 02:13
Mandar
mixer is on a distinguished road
Hi Barath
The epsilon and omega are getting out of bounds,
Use the 'limited settings' for laplacian of omega and epsilon, say,
laplacian(DepsilonEff,epsilon) Gauss linear limited 0.3;
laplacian(DomegaEff,omega) Gauss linear limited 0.3;
also, possibly see if BC value's of epsilon and omega can be made more realistic.
mixer is offline   Reply With Quote
Old   July 14, 2009, 04:34
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
Try to decrease your deltaT, your max Courant number is very high (it should be <1). Also, run your case first with upwind on div convection terms, and change your relTol to 0 for all variables in fvSolution.
Regards,
Jose Santos
santos is offline   Reply With Quote
Old   July 14, 2009, 06:51
Default Limited settings not working
Barath Ezhilan
Hi Menter,
I have tried applying the limited settings, but it still doesnt seem to work. Please tell what else can be done.
Originally Posted by mixer View Post
Hi Barath
Old   July 14, 2009, 06:55
Default Hi!!!
Barath Ezhilan
Hi Jose Santos,
I have chosen a time step 5E-5 and the initial courant number is quite low only (of the order of 1E-3). My FvSolution doesnot have any relTol, (I am using the settings provided in the cavity folder of TURBfoam tutorials) Will that be in any way the reason for the problem?
Regards,
Jose Santos
Old   July 15, 2009, 05:05
santos's Avatar
Jose Luis Santos
Does it still diverge with those settings? The settings you showed on your first post were different.
Jose Santos
Old   July 15, 2009, 05:35
Barath Ezhilan
Hi santos,
Which settings are you referring to ??
My first post also shows the deltaT settings to be 5E-5 (deltaT 0.00005), and the courant number of the first few time steps was also 1E-3 .
Jose Santos
Old   July 15, 2009, 05:45
santos's Avatar
Jose Luis Santos
Your mean Co was 1e-3, but your max Co = 7. Moreover, the fvSolution you showed has relTol 0.01 and 0.1 for most variables.
Jose Santos
Old   July 15, 2009, 05:51
Barath Ezhilan
Hi Santos,
Thanks, I will change the relTol, and try simulating
Jose Santos
Old   July 15, 2009, 18:29
Barath Ezhilan
Hi Santos,
I changed the relTol settings to 0 and simulated. The problem still exists (as you see below, in the log file)!!!! any suggestions??
Time = 5e-05
Courant Number mean: 0.000358108 max: 0.243795 velocity magnitude: 3.22114
PBiCG: Solving for Ux, Initial residual = 1, Final residual = 1.81664e-06, No Iterations 2
PBiCG: Solving for Uy, Initial residual = 1, Final residual = 1.82548e-06, No Iterations 2
PBiCG: Solving for Uz, Initial residual = 1, Final residual = 5.26316e-06, No Iterations 3
PCG: Solving for p, Initial residual = 1, Final residual = 9.93795e-07, No Iterations 439
PCG: Solving for p, Initial residual = 0.0190973, Final residual = 9.01639e-07, No Iterations 359
PCG: Solving for p, Initial residual = 0.00380892, Final residual = 9.84682e-07, No Iterations 353
time step continuity errors : sum local = 2.62486e-08, global = -8.42758e-11, cumulative = -8.42758e-11
PCG: Solving for p, Initial residual = 0.00477481, Final residual = 9.89681e-07, No Iterations 360
PCG: Solving for p, Initial residual = 0.00557558, Final residual = 9.75184e-07, No Iterations 353
PCG: Solving for p, Initial residual = 0.00209781, Final residual = 9.6199e-07, No Iterations 346
time step continuity errors : sum local = 2.32097e-08, global = 6.46285e-12, cumulative = -7.78129e-11
PCG: Solving for p, Initial residual = 0.00252374, Final residual = 9.31564e-07, No Iterations 346
PCG: Solving for p, Initial residual = 0.00159287, Final residual = 9.71556e-07, No Iterations 342
PCG: Solving for p, Initial residual = 0.00109841, Final residual = 9.93416e-07, No Iterations 338
time step continuity errors : sum local = 2.37934e-08, global = 1.25654e-10, cumulative = 4.78414e-11
PCG: Solving for p, Initial residual = 0.00147234, Final residual = 9.52147e-07, No Iterations 341
PCG: Solving for p, Initial residual = 0.00126403, Final residual = 8.98022e-07, No Iterations 338
PCG: Solving for p, Initial residual = 0.00100686, Final residual = 9.89063e-07, No Iterations 333
time step continuity errors : sum local = 2.36568e-08, global = 1.71118e-10, cumulative = 2.1896e-10
PBiCG: Solving for omega, Initial residual = 0.0079402, Final residual = 4.81707e-06, No Iterations 2
bounding omega, min: -39.8115 max: 12127.3 average: 105.149
PBiCG: Solving for k, Initial residual = 1, Final residual = 2.89074e-06, No Iterations 5
ExecutionTime = 606.88 s ClockTime = 614 s
Time = 0.0001
Courant Number mean: 0.00502222 max: 0.918015 velocity magnitude: 5.37594
PBiCG: Solving for Ux, Initial residual = 0.335416, Final residual = 2.71144e-07, No Iterations 3
PBiCG: Solving for Uy, Initial residual = 0.335463, Final residual = 2.6876e-07, No Iterations 3
PBiCG: Solving for Uz, Initial residual = 0.863441, Final residual = 5.86173e-06, No Iterations 2
PCG: Solving for p, Initial residual = 0.00982878, Final residual = 8.78105e-07, No Iterations 372
PCG: Solving for p, Initial residual = 0.20334, Final residual = 9.20665e-07, No Iterations 384
PCG: Solving for p, Initial residual = 0.0678486, Final residual = 9.55188e-07, No Iterations 380
time step continuity errors : sum local = 2.04639e-09, global = 3.35027e-13, cumulative = 2.19295e-10
PCG: Solving for p, Initial residual = 0.0850855, Final residual = 9.56664e-07, No Iterations 379
PCG: Solving for p, Initial residual = 0.38827, Final residual = 9.73532e-07, No Iterations 390
PCG: Solving for p, Initial residual = 0.316163, Final residual = 9.23616e-07, No Iterations 386
time step continuity errors : sum local = 4.21096e-10, global = 2.25754e-13, cumulative = 2.1952e-10
PCG: Solving for p, Initial residual = 0.424259, Final residual = 9.47635e-07, No Iterations 386
PCG: Solving for p, Initial residual = 0.474849, Final residual = 9.68887e-07, No Iterations 382
PCG: Solving for p, Initial residual = 0.512805, Final residual = 9.25307e-07, No Iterations 381
time step continuity errors : sum local = 4.93901e-10, global = -4.74778e-13, cumulative = 2.19046e-10
PCG: Solving for p, Initial residual = 0.618267, Final residual = 9.08134e-07, No Iterations 380
PCG: Solving for p, Initial residual = 0.645274, Final residual = 9.47856e-07, No Iterations 379
PCG: Solving for p, Initial residual = 0.684602, Final residual = 9.86349e-07, No Iterations 378
time step continuity errors : sum local = 8.37812e-10, global = -4.68039e-13, cumulative = 2.18578e-10
PBiCG: Solving for omega, Initial residual = 0.415049, Final residual = 8.50722e-06, No Iterations 8
bounding omega, min: -2.38491e+06 max: 3.60791e+07 average: 6236.52
PBiCG: Solving for k, Initial residual = 0.65272, Final residual = 1.54235e-06, No Iterations 4
bounding k, min: -0.00274926 max: 0.127536 average: 0.0102244
ExecutionTime = 1240.58 s ClockTime = 1253 s
Time = 0.00015
Courant Number mean: 0.00524007 max: 5.76168 velocity magnitude: 44.0043
PBiCG: Solving for Ux, Initial residual = 0.0672304, Final residual = 9.43873e-06, No Iterations 6
PBiCG: Solving for Uy, Initial residual = 0.0670888, Final residual = 1.98847e-06, No Iterations 7
PBiCG: Solving for Uz, Initial residual = 0.00481512, Final residual = 7.2339e-06, No Iterations 4
PCG: Solving for p, Initial residual = 0.824352, Final residual = 9.17862e-07, No Iterations 389
PCG: Solving for p, Initial residual = 0.698699, Final residual = 9.93409e-07, No Iterations 384
PCG: Solving for p, Initial residual = 0.727276, Final residual = 9.97471e-07, No Iterations 387
time step continuity errors : sum local = 1.60855e-09, global = -1.68868e-12, cumulative = 2.16889e-10
PCG: Solving for p, Initial residual = 0.876338, Final residual = 9.49251e-07, No Iterations 389
PCG: Solving for p, Initial residual = 0.84503, Final residual = 9.53187e-07, No Iterations 391
PCG: Solving for p, Initial residual = 0.879094, Final residual = 8.97079e-07, No Iterations 392
time step continuity errors : sum local = 2.47347e-09, global = -1.6306e-12, cumulative = 2.15258e-10
PCG: Solving for p, Initial residual = 0.95115, Final residual = 9.62471e-07, No Iterations 391
PCG: Solving for p, Initial residual = 0.87138, Final residual = 9.16364e-07, No Iterations 392
PCG: Solving for p, Initial residual = 0.887653, Final residual = 9.34473e-07, No Iterations 392
time step continuity errors : sum local = 4.73105e-09, global = 2.88022e-12, cumulative = 2.18139e-10
PCG: Solving for p, Initial residual = 0.962629, Final residual = 9.87552e-07, No Iterations 390
PCG: Solving for p, Initial residual = 0.883919, Final residual = 9.9326e-07, No Iterations 392
PCG: Solving for p, Initial residual = 0.905319, Final residual = 9.56255e-07, No Iterations 393
time step continuity errors : sum local = 8.67916e-09, global = -2.17652e-12, cumulative = 2.15962e-10
PBiCG: Solving for omega, Initial residual = 0.557895, Final residual = 8.90059e-06, No Iterations 30
bounding omega, min: -1.9486e+07 max: 5.4919e+08 average: 159539
PBiCG: Solving for k, Initial residual = 0.607767, Final residual = 6.63983e-06, No Iterations 5
bounding k, min: -0.254928 max: 1.0788 average: 0.0112812
ExecutionTime = 1902.14 s ClockTime = 1924 s
Time = 0.0002
Courant Number mean: 0.0120517 max: 243.737 velocity magnitude: 1747.7
PBiCG: Solving for Ux, Initial residual = 0.760947, Final residual = 8.84033e-06, No Iterations 39
PBiCG: Solving for Uy, Initial residual = 0.774137, Final residual = 3.97576e-06, No Iterations 38
PBiCG: Solving for Uz, Initial residual = 0.506527, Final residual = 9.29213e-06, No Iterations 33
PCG: Solving for p, Initial residual = 0.78, Final residual = 8.87942e-07, No Iterations 615
PCG: Solving for p, Initial residual = 0.547448, Final residual = 7.41311e-07, No Iterations 601
PCG: Solving for p, Initial residual = 0.455372, Final residual = 6.3829e-07, No Iterations 620
time step continuity errors : sum local = 7.9754e-09, global = 6.46518e-11, cumulative = 2.80614e-10
PCG: Solving for p, Initial residual = 0.832319, Final residual = 8.24641e-07, No Iterations 601
PCG: Solving for p, Initial residual = 0.487072, Final residual = 7.58123e-07, No Iterations 619
PCG: Solving for p, Initial residual = 0.354087, Final residual = 8.01443e-07, No Iterations 604
time step continuity errors : sum local = 4.46259e-08, global = -6.1831e-11, cumulative = 2.18783e-10
PCG: Solving for p, Initial residual = 0.978763, Final residual = 6.43371e-07, No Iterations 616
PCG: Solving for p, Initial residual = 0.487253, Final residual = 9.60152e-07, No Iterations 602
PCG: Solving for p, Initial residual = 0.33208, Final residual = 3.72602e-07, No Iterations 596
time step continuity errors : sum local = 6.06844e-07, global = 4.93755e-09, cumulative = 5.15634e-09
PCG: Solving for p, Initial residual = 0.983923, Final residual = 9.73328e-07, No Iterations 606
PCG: Solving for p, Initial residual = 0.48976, Final residual = 7.46673e-07, No Iterations 591
PCG: Solving for p, Initial residual = 0.291791, Final residual = 6.55602e-07, No Iterations 587
time step continuity errors : sum local = 4.414e-05, global = 7.197e-07, cumulative = 7.24857e-07
PBiCG: Solving for omega, Initial residual = 0.999997, Final residual = 3.08064e+07, No Iterations 1000
bounding omega, min: -7.25689e+24 max: 5.46641e+24 average: -1.03469e+20
PBiCG: Solving for k, Initial residual = 0.81231, Final residual = 3.54624e-11, No Iterations 1
bounding k, min: -53823.1 max: 106.182 average: -6.48604
ExecutionTime = 3236.79 s ClockTime = 3276 s
Time = 0.00025
Courant Number mean: 25.0656 max: 2.5079e+07 velocity magnitude: 2.38043e+08
PBiCG: Solving for Ux, Initial residual = 0.999999, Final residual = 0.999999, No Iterations 1000
PBiCG: Solving for Uy, Initial residual = 0.999999, Final residual = 0.999999, No Iterations 1000
PBiCG: Solving for Uz, Initial residual = 0.999999, Final residual = 1.16832, No Iterations 1000
PCG: Solving for p, Initial residual = 0.999999, Final residual = 0.119066, No Iterations 1000
PCG: Solving for p, Initial residual = 0.0904133, Final residual = 3.89395, No Iterations 1000
PCG: Solving for p, Initial residual = 0.796989, Final residual = 2.27701, No Iterations 1000
time step continuity errors : sum local = 3.30829e+08, global = 1.40983e-06, cumulative = 2.13468e-06
PCG: Solving for p, Initial residual = 0.999459, Final residual = 4.68481, No Iterations 1000
PCG: Solving for p, Initial residual = 0.870245, Final residual = 1.35971, No Iterations 1000
PCG: Solving for p, Initial residual = 0.848326, Final residual = 6.07145, No Iterations 1000
time step continuity errors : sum local = 6.48284e+13, global = 0.0104131, cumulative = 0.0104153
PCG: Solving for p, Initial residual = 0.999416, Final residual = 1.60614, No Iterations 1000
PCG: Solving for p, Initial residual = 0.831019, Final residual = 1.93253, No Iterations 1000
PCG: Solving for p, Initial residual = 0.833148, Final residual = 2.24912, No Iterations 1000
time step continuity errors : sum local = 2.18907e+18, global = -93.1258, cumulative = -93.1154
PCG: Solving for p, Initial residual = 0.999613, Final residual = 6.6956, No Iterations 1000
PCG: Solving for p, Initial residual = 0.880524, Final residual = 37.3175, No Iterations 1000
PCG: Solving for p, Initial residual = 0.880441, Final residual = 3.30312, No Iterations 1000
time step continuity errors : sum local = 1.23502e+25, global = -5.00345e+08, cumulative = -5.00345e+08
Jose Santos
Old   July 15, 2009, 18:32
Barath Ezhilan
And I dont think there is much of a problem with the initial settings also. Because i tested the same case with transient Simple Foam and it runs properly. What could be the reason for this discrepancy with respect to TURBFOAM???
Jose Santos
Originally Posted by barath.ezhilan View Post
Hi santos,
Old   July 15, 2009, 21:08
Mandar
Hi Barath
Is this still happening if you initialize the turbfoam with your simpleFoam results? The simplefoam is a steadystate solver, the transient thing isn't possible with it. Your pressure iterations are taking long time to converge. Try using GAMG solver for Pressure, and the suggestions by Jose for limiting ur courant number.
Old   July 16, 2009, 05:46
Barath Ezhilan
Hi Mandar,
I was referring to the solver transientSimpleFoam, anyways I will change the solver to GAMG and check
Hi Barath
Old   July 16, 2009, 05:55
santos's Avatar
Jose Luis Santos
I agree with Mandar, maybe what you are missing is an adequate field initialization. If you dont want to use simpleFoam for that, potentialFoam is also a good option.
Anyway, you could use an even lower deltaT in the first iterations just to make sure your Co stabilizes. Then you can increase your deltaT to a better value.
Regards,
Jose Santos
courant number increasing, turbfoam
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 12:13
problems with turbFoam (small deltaT) sven82 OpenFOAM Running, Solving & CFD 1 May 26, 2009 08:03
Problems with simulating an impeller Hannes FloEFD, FloWorks & FloTHERM 8 September 17, 2008 09:05
Problems turbFoam harwin OpenFOAM Pre-Processing 6 December 7, 2006 05:36
Inlet problems with turbFoam jonititan OpenFOAM Running, Solving & CFD 1 May 4, 2006 03:24
